acura remote start
ksingh
Copper - Posts: 62
Posted: November 20, 2004 at 10:24 AM / IP Logged
HEY WHAT UP I FINISHED MY INSTALL AND COME TO FIND OUT THE STARTER KILL IS NOT WORKIN EVERYTHING ELSEWORKS FINE AND I CANT SEEM TO FIGURE OUT WHAT IS GOING ON
1999 ACURA 3.2TL USING VIPER791
STARTER KILL RELAY HAS WIRE COLORS:
PINK/WHITE
PINK
GREEN
PURPLE
ORANGE
RED 12V
RED / WHITE 12V
THE GREENIS TO THE KEY SIDE AND THE PURPLE IS TO THE STATER
ORANGE IS TO ACC
I GOT THE OTHER WIRES HOOKED UP ALREADY
NOW WHATI AM PUZZLED ABOUT IS THAT THERE IS ANOTHER ORANGE WIRE THAT IS SKINNY FROM COMMING FROM THE HARNESS THAT POWERS UP THE BRAIN THAT IS SUPPOSE TO GO TO ACC I BELIEVE BUT WHEN I HOOK THAT WIRE UP THE CAR WONT START WITH THE KEY BUT WHEN I UNHOOK THAT WIRE IT WILL START FINE
THAT ORANGE WIRE IS THE ARMED OUTPUT ORANGE
PLEASE HELP
Kenny
AutoAcoustics
Member - Posts: 11
Posted: November 20, 2004 at 10:41 AM / IP Logged
The starter kill relay should have an orange wire coming off of it.  Connect that to the orange ground when armed wire coming off the brain.  The yellow wire coming off the starter kill relay should go to a true ignition.  Hope this helps.  Later
Paul Walker
Auto Acoustics
Hillsborough, NC
ksingh
Copper - Posts: 62
Posted: November 20, 2004 at 10:51 AM / IP Logged
WHAT YOU ARE SAYING IS MAKING SENSE TO ME
I HAD THE 2 ORANGE WIRES CONNECTED TOGETHER AND THE CAR WONT START WITH THE KEY IN THE IGN SO WHAT I DID WAS DOUBLE CHECK MY WIRES ON THE RELAY PACK HARNESS AND THEN IT WAS FINE SO I DISCONNECT THAT ORANGE WIRE THE SKINNY GUAGE AND IT STARTS FINE
NOW ONE THIS IS THAT THERE IS NO YELLOW WIRE COMMING OFF OF THE RELAY PACK ONLY YELLOW IS FROM THE RIBBON
Kenny
AutoAcoustics
Member - Posts: 11
Posted: November 20, 2004 at 12:13 PM / IP Logged
Check again.  Every DEI starter kill relay I've ever seen has a green, black, orange, and yellow wire.
Paul Walker
Auto Acoustics
Hillsborough, NC
