blinking LED's on when truck is off?
pfitz
Copper - Posts: 53
Posted: December 02, 2004 at 11:05 AM / IP Logged
I have one of those Radio Shack blinking LED's.  I want it to come on when the truck is OFF and to shut off when the ignition is ON.  I know this is a simple procedure, but I just can't wrap my brain around it?
blinking LED's on when truck is off? -- posted image.
A little help please!
the12volt
Administrator - Posts: 3,959
Posted: December 02, 2004 at 11:22 AM / IP Logged
Connect terminal 85 of an SPDT relay to ground, terminal 86 to ignition, terminal 30 to LED(s) positive, terminal 87a to constant 12V positive. When the ignition is on, the normally closed terminals of the relay will open, turning off the LED(s). Depending on the LED(s) you have, you may need to add resisitors to the LED(s).
blinking LED's on when truck is off? -- posted image. the12volt • Support the12volt.com
ff-mike
Copper - Posts: 199
Posted: December 03, 2004 at 4:33 PM / IP Logged
I would do almost the same thing as the12volt except I would switch the LED positive to #87a terminal and connect #30 to the supply (constant 12v). This way you could use #87 as a feeder for a circuit that you only want when the ignition is on- ie a steady green LED to let the signficant other that the car is already on or to feed amps or something similiar
diabloscope
Member - Posts: 48
Posted: December 07, 2004 at 3:05 AM / IP Logged
 even easier  way and still as safe   .  the positve   side  L.E.D.   to constant , and the  Neg side of L.E.D.  to true Ignition.   true ingition  rests at ground
diabloscope
Member - Posts: 48
Posted: December 07, 2004 at 3:07 AM / IP Logged
 even easier  way and still as safe   .  the positve   side  L.E.D.   to constant , and the  Neg side of L.E.D.  to true Ignition.   true ingition  rests at ground   ,   thats what you asked for when the key is off the L.E.D. turns on , and off when key is on.
jaxon23
Member - Posts: 25
Posted: December 07, 2004 at 8:12 AM / IP Logged
but he wants it to blink like an alarm LED not just burn steady
ff-mike
Copper - Posts: 199
Posted: December 07, 2004 at 8:30 AM / IP Logged
This is a blinking LED out of the box. So it will blink with constant 12v. AFAIK, ignition has no connection at ground, so the option from 12v to ignition would be invalid.
pfitz
Copper - Posts: 53
Posted: December 07, 2004 at 10:56 AM / IP Logged
OK, it is a 1992 Toyota 4X4 truck, what color is the wire and where would I find it?
ff-mike
Copper - Posts: 199
Posted: December 07, 2004 at 11:26 AM / IP Logged
This sites info
Accessory to terminal 86
Constant 12v to terminal 30
LED anode to terminal 87a
Ground to terminal 85
diabloscope
Member - Posts: 48
Posted: December 08, 2004 at 1:54 AM / IP Logged
yes all cars   true ignition rests at ground   and for your car is black wire w/ yellow stripe , in the main ignition harness   constant is  a  white wire  in the same loom,
