doors lock
patmar
Copper - Posts: 69
Posted: November 17, 2002 at 3:01 PM / IP Logged
i'm install a remote starter astrostart rs 113 in a nissan altima 2003 . for the unlock  i need double pulse for unlock but i don't have in feature. if you have a diagram to convert double pulse with single take me please. i need other tink when lock my doors i'm try to use the factory horns to confirm the doors is locked but the signal is too long .i need the diagrm to connect my horn with my locks
tank
pat
djfearny2
Silver - Posts: 810
Posted: November 17, 2002 at 8:22 PM / IP Logged
FIRST YOU NEED TO BUY  a two pin flasher cam to put in the line of the horns this will also act as a siren it will go beep --- beeep  instead of one beeeeeeep.  you need this, just take the flasher and what ever your thowing the horn cut the wire inside the car and connect one side to one pin on flasher and other side of wire to other, and as for yopur door locks this is a little thing you can buy many companyies have them go to a sound shop tell them what you are trying to do and they will be able to help you if you go to one shop they dont know than go somewhere else.
Jon
Installer/Help Technician
---coral springs florida---
Player69
Silver - Posts: 504
Posted: November 17, 2002 at 9:09 PM / IP Logged
On the astro start you can program one of the aux wires to do a pulse before.  If you hook that up and also your unlock output it will provide a double unlock.  (Pulse before unlock then the actual unlock)
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
