relay question
n8eight
Posted: June 24, 2005 at 2:34 PM / IP Logged
I am woring on a misting system that is hooked to a 12 volt irrigation timer. The timer only outputs a single charge for on and off times.  Can you use a single charge to open a relay and then another single charge to close a relay.  This way the current is flowing during the entire time and my 12volt pump will run the whole time.  I would use a second 12volt battery to run the pump.
hotwaterwizard
Silver - Posts: 1,350
Posted: June 25, 2005 at 7:57 PM / IP Logged
Yes but I need more details.
Are you trying to turn one relay on and off?
Are you trying to turn a relay on and a second one on or off?
Why do you need a Timer if you want the pump running all the time?
I can help you but I need to understand exactly what you want to do.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
n8eight
Posted: June 26, 2005 at 6:14 AM / IP Logged
Since I am keeping this all on 12 volt or less  the timer I am using sends a single pulse of electricity.  The timer is for a irrigation solenoid and valve.  One charge to open the solenoid and one more to close the solenoid.  Well, I want to use a water pump to drive my misting system, but it needs to run continuously through the cycle of the timer.  Since this timer does not do that.  I was wondering how i can keep the juice flowing to the pump.
www.daynicontrols.com/  for the timer
http://www.oberread.com/aquatec.htm  the 12volt booster pump
I want to be able to set a schedule for my misting system and not have to worry about turning the system on or off during the day.
If this is still not enough info i can send you a diagram as well.
hotwaterwizard
Posted: July 19, 2005 at 11:29 PM / IP Logged
A diagram would help. So does this timer have a positive and negitive that switches polarity for up and down?
Are you sure that you are seting the timing cycle right?
This looks like a good timer.
Stockton California
hotwaterwizard
Posted: July 19, 2005 at 11:32 PM / IP Logged
relay question -- posted image.
Stockton California
