Dimmer with relay
lateral4
Posted: July 04, 2005 at 12:30 PM / IP Logged
I had to switch the polarity on a domelight for a overhead dvd system in 05 Hyundai Tucson and it has a light that dims out so the relay buzzez untill it is at full ground. Does anyone know how I can get rid of that dimmer and just make it full 12volt or full ground?
I've got nothing fancy to say!
genehewett
Copper - Posts: 151
Posted: September 14, 2005 at 8:53 PM / IP Logged
The door trigger wire is neg. and found in the following location. Only use this to trigger a relay do not connect any load to it like a dvd system.
Door Trigger yellow/black or yellow/orange  -  driver kick, 23 pin plug, pin 6
Notes: Also found at the ETACM (Electronic Time and Alarm Control Module) under the front center console, 26 pin plug, pin 6.
