Special Relay setup?
jeepcj92
Member - Posts: 46
Posted: December 08, 2002 at 12:46 PM / IP Logged
Here's what I want to accomplish.  I want to set up something that will emit a single pulse (ground) from two sequential pulses (positive)....  If the second pulse is not completed within a few seconds then the circuit will not complete.
I've been searching for some kind of time delay relay, but have not had any luck.  The ultimate goal is to make a channel replcator to activate a remote start off of a factor keyless entry.  Another thought is to have some kind of time delay relay on the unlock circut... and a regular relay on the lock circut.  Press unlock, and the time delay keeps the half of the circut closed for a second, and then hit lock and a regular relay completes the full circuit.
could this work? where could I get a relay that would stay active for a few seconds??
thanks
jeepcj92
Member - Posts: 46
Posted: December 08, 2002 at 9:48 PM / IP Logged
Would this work:
Special Relay setup? -- posted image.
Lets say that this is activated by the unlock circut from the factory keyless entry. This relay is ganged with another relay that would be in series with the first(delayed) relay. Then while the first relay it is active, if the lock button is pressed it will close the second relay which will ground the pulsed input for the remote start and thus start the car.
-Jeff
KBToys
Copper - Posts: 74
Posted: December 16, 2002 at 8:00 AM / IP Logged
DEI makes a timed relay which I just got but am trying to understand how it works. Model# DEI 528T
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
