Relay for Neon Lighting
Tribal_Dog
Member - Posts: 16
Posted: December 23, 2002 at 6:58 AM / IP Logged
This is my first post on this board and I have been reading alot about relays and how benifitial they are to the 12Volt world.
The question i have is where in the circuit would i put a relay to control the neon lights? And how would i wire up the relay? I have main power running into the car and 6 different switches controling different lights.
brianh
Silver - Posts: 518
Posted: December 23, 2002 at 2:49 PM / IP Logged
How do you want to co0ntrol them.  With the switchs that you already have or with your alarm?  Brian
Tribal_Dog
Member - Posts: 16
Posted: December 23, 2002 at 4:28 PM / IP Logged
They will be controlled by a main switch.
brianh
Silver - Posts: 518
Posted: December 23, 2002 at 7:20 PM / IP Logged
Well if you want one main switch to turn all of them on all you need to do is to use a relay.  Run 12 volts to your main switch and then to pin 85 on the relay.  Then run a wire from pin 86 to ground.  Then take the 12 volt feed that feeds all the lights now and put it on pinn 87.  Finally run the + wires from the lights to pin 30.(or you can run them all together and attach them to a larger wire( that can handle the current of all the lights).  Let us know how it works out.  Brian
Tribal_Dog
Member - Posts: 16
Posted: December 24, 2002 at 5:23 AM / IP Logged
Thanks for your help........i plan to try this as soon as i have some spare time.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
