Auto Unlock Relay
Sungura222
Member - Posts: 47
Posted: January 23, 2006 at 12:24 PM / IP Logged
I want to add auto unlock to my car which has positive Door Locks.
I have looked at the Door locks section of the 12Volt install bay.
Do i connect it up according to the 'Constant to Momentary Output' relay diagram?
i.e. Relay Pin: 86 - Switched 12V+
              Pin: 87 -  Fused 12V+
              Pin: 85 - Ground via a 1K uf capacitor & a 10K fixed resistor
              Pin 30 - momentary 12V(+) to door Unlock wire
The Diagram in the Install bay also shows a connection between pins 86 & 85 with a diode pointing towards pin 86
Why Do I need to make this connection?
Also should I not add a diode on the switched 12V(+) wire with the diode pionting towards pin 86,  hence preventing 12volts from flowing back?
Any help appreciated
regards.
Sungura
infinkc
Copper - Posts: 438
Posted: January 29, 2006 at 12:37 PM / IP Logged
get a PAC Tr7 and make like easy
There are 10 types of people in the world, ones that understand binary and ones that dont.
