relay help
superman121880
Member - Posts: 22
Posted: January 04, 2003 at 12:27 PM / IP Logged
Im trying to get get negative out put from a relay when i put a positive inout ( positive switch to power a negative horn) .. How can i wire up that relay...????please help... Thanks...
superman
brianh
Silver - Posts: 518
Posted: January 04, 2003 at 1:11 PM / IP Logged
If your trigger wire is positive all you need to is:  Pin 85 to trigger wire.  Pin 86 to ground.  Pin 87 to ground and pin 30 to the horn wire.   Good luck.  Brian
superman121880
Member - Posts: 22
Posted: January 04, 2003 at 2:49 PM / IP Logged
 brian thanks,
  Worked out perfect..!!!
superman
brianh
Silver - Posts: 518
Posted: January 04, 2003 at 4:10 PM / IP Logged
No problem,glad I could help you.  Brian
