Constant corning lighta-problem
iceman99
Member - Posts: 9
Posted: April 18, 2006 at 5:33 PM / IP Logged
Hi y'all
I am trying to put cornering lights on my Monte Carlo, activated from the front turn signals. The problem I'm having is that the cornering light flashes with the turn signal, instead of remaining steady.  The diagram I'm using is this:
Constant corning lighta-problem -- posted image.
The only difference in the diagram is that I soldered the capactor and resistor in one spot on the wire and together to ground.  I have the two didoes in the circuit, just like shown.  The light that I'm using are led's, from superleds.com.  They are grouped in 6, and in a small case.
Should I connect the capactor and resistor in different spots, like shown in the diagram?
Like I said, the cornering light comes on, but it flashes in sequesnce with the turn signal.  The relay clicks/cycles with the flashing turn signal.  I can't figure it out.  Any suggestions would be appreciated.
Iceman
T H E   I C E M A N   C O M M E T H !!!!!!
All information is provided "as is" without any warranty of any kind.
iceman99
Member - Posts: 9
Posted: April 18, 2006 at 5:36 PM / IP Logged
Plese excuse my typing errors/spelling, I couldn't figure out how to edit it.
iceman99
Member - Posts: 9
Posted: April 19, 2006 at 12:27 PM / IP Logged
Constant corning lighta-problem -- posted image.    AnyOne???? I'm sure it's something simple on my part.  I just can't figure it out.
txs
Iceman
iceman99
Member - Posts: 9
Posted: May 12, 2006 at 4:13 PM / IP Logged
Aw, JUST FORGET IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Constant corning lighta-problem -- posted image.Constant corning lighta-problem -- posted image.
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
