low voltage sensor ckt.
slofy
Posted: February 09, 2007 at 9:59 PM / IP Logged
I have a different thing that I am trying.  I have been installing 12v power inverters in service trucks.  I have installed remote starts for manual battery maintenance after a heavy load.  I am pulling my hair out trying to find a relay or ckt to sense a low battery voltage to switch a 12v relay to trigger remote start automatically.  does anyone have any ideas? thanks charlie
(slofy) Charles Fols
        Delaware
hotwaterwizard
Silver - Posts: 1,350
Posted: February 09, 2007 at 10:18 PM / IP Logged
I like this idea . Lets see what we can come up with.
low voltage sensor ckt. -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
hotwaterwizard
Posted: February 09, 2007 at 10:35 PM / IP Logged
Stockton California
slofy
Posted: February 10, 2007 at 5:42 AM / IP Logged
Thank you very much, but how should i trigger a relay to give me a ground pulse?
        Delaware
hotwaterwizard
Posted: February 10, 2007 at 8:15 AM / IP Logged
with a Opto isolator where the led goes.
Stockton California
KPierson
Platinum - Posts: 3,527
Posted: February 10, 2007 at 3:00 PM / IP Logged
You could also use a voltage divider with a 5vdc reference.
If you set up the voltage divider with a 1:3 ratio it will divide your car voltage by 3.  You can then use a seperate trimpot to to set your scaled low voltage limit.j
Run both of these values in to a comparator and transistorize the output and you're done.
No pretty pictures from me though!  :)
Kevin Pierson
KPierson
Posted: February 10, 2007 at 3:02 PM / IP Logged
You may also want to do a bit of research on this before you install it.  Any big shifts in load will cause a voltage drop, which could provide false triggers.  You may want to consider adding a time delay to the circuit to prevent the truck from starting any time you turn something on.
Kevin Pierson
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
