plug in flasher relay verses spdt relay
nautikalhorizon
Posted: April 03, 2007 at 6:35 PM / IP Logged
I am new to the relay business, so therefore I wanting to know if there is a difference. The relay(s) I bought does not specify whether it is a SPDT or not...it doesn't have any numbers by the terminal. However it is a 12v 5 terminal relay. Is it the same as a SPDT or are the OE Flasher replacements totally different? Thanks in advance,
Jas
hotwaterwizard
Silver - Posts: 1,350
Posted: April 03, 2007 at 8:59 PM / IP Logged
Got a picture or Part number?
The pins are marked on the bottom near the base.
I have not seen one yet that is not marked.
Probably not the same. Flasher relays are usually Double poll single throw.
plug in flasher relay verses spdt relay -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
hotwaterwizard
Posted: April 03, 2007 at 10:28 PM / IP Logged
It would be easier if You posted a picture or part number or something.
Stockton California
