latching relay
rtm038
Member - Posts: 41
Posted: July 02, 2007 at 1:07 PM / IP Logged
Can you switch the "state" of a latching relay using a momentary 12+VDC pulse, via a NO pushbutton momentary switch?
hotwaterwizard
Silver - Posts: 1,350
Posted: July 02, 2007 at 10:07 PM / IP Logged
i believe you can.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
hotwaterwizard
Posted: July 03, 2007 at 8:30 AM / IP Logged
latching relay -- posted image.
Stockton California
rtm038
Member - Posts: 41
Posted: July 03, 2007 at 5:00 PM / IP Logged
Yeah I saw that diagram using the 4 relays, but it looks like the switch provides a pulsed/momentary ground.  Now I can wire mine like that, but it would be easier (for me) to use a pulsed/momentary 12+VDC pulse.  This there a way to do it using the above diagram?
hotwaterwizard
Posted: July 04, 2007 at 2:01 PM / IP Logged
Stockton California
rtm038
Member - Posts: 41
Posted: July 04, 2007 at 7:07 PM / IP Logged
O.K., I used the 4-relay set-up and it works perfectly!  Thanks everyone for your help.  Now, the only think I don't like about this set-up is the size of assembly itself.  Can anyone recommend a smaller in size relay that can handle the loads a regular "Bosch" style relay can handle?
hotwaterwizard
Posted: July 05, 2007 at 8:24 AM / IP Logged
You could use 4 tiny relays then add one bosch style on the output as the one that carries the load.
Stockton California
rtm038
Member - Posts: 41
Posted: July 05, 2007 at 12:02 PM / IP Logged
O.K....great.
Thanks again
Ryan
