mouse over opens a preview of the post
Platinum - Posts: 13,726
Posted: August 24, 2009 at 11:23 PM / IP Logged
I know I said I was done for a whie, well I lied.  This would be most helpful on the forums and especially on the Last 100.   Mouse over shows the first part of the post.  You know how some of our subject lines are not even close to the actual problem(s).  It is just easier to mouse over and preview to decide whether or whether not you will be able to help.
the12volt
Administrator - Posts: 3,959
Posted: August 24, 2009 at 11:30 PM / IP Logged
Let me play with it to find the best way to do it without putting too much of a performance hit on the server. The first thing that comes to mind is to display the first 100 characters of the first post in a title tag.  I'll try to get to it this week.
Example
mouse over opens a preview of the post -- posted image. the12volt • Support the12volt.com
Posted: August 24, 2009 at 11:34 PM / IP Logged
Perfect.  That was exactly how I was imagining it.
the12volt
Posted: August 25, 2009 at 12:12 AM / IP Logged
I just added this feature to the last 100 for now. I've stripped HTML tags from the title tag to prevent output errors. We'll see how well this does for now before I consider adding it elsewhere.
Posted: August 25, 2009 at 4:53 AM / IP Logged
The last 100 is the only one I use.  And it works great.  Thank you.
the12volt
Posted: August 25, 2009 at 10:56 AM / IP Logged
Koo. You're welcome.
the12volt
Posted: August 25, 2009 at 11:19 AM / IP Logged
I just added this feature to the forum pages.
Posted: August 25, 2009 at 8:35 PM / IP Logged
If everybody likes it half as much as I do,  you did good.  It really is helpful.
Posted: August 27, 2009 at 12:39 AM / IP Logged
Did we do away with adding an image to your signature line, or am I just an idiot and can not figure out how to do it?
the12volt
Posted: August 27, 2009 at 1:28 PM / IP Logged
Koo.
Nope, you can still add small images. Click on the "Forum Codes" link just above the Post Reply button below.
Page of 3
