dedicated remote starter forum
defective
Silver - Posts: 642
Posted: November 15, 2003 at 8:49 AM / IP Logged
how about a dedicated remote starter forum, this would be great so that i can distinguish it from the security stuff.  People go into the security forum and go
"i need a diagram for a 99 ford explorer"
I get all my info out of The Book, so i have to type everything out. If i knew they didn't need the doorpins and stuff i wouldn't have to type so much and could have more time to help others too.
this has probably been asked a bunch of times but i thought i would give it a swing, maybe because of liability issues or something casue you have to be certified to install starters.   dunno, just a thought
the12volt
Administrator - Posts: 3,959
Posted: November 15, 2003 at 11:30 AM / IP Logged
Hi Josh, thanks for the idea. I understand the problem with vague topics and members should as well, but I don't think creating a dedicated forum for remote starters will solve the problem.
If we did add a dedicated forum for remote starters, it would create some new problems. Members installing an alarm or keyless entry with a remote starter would be posting similar topics in both forums which would defeat the purpose of the dedicated forum in the first place. This would then make it more difficult to search for specific vehicle information, and the most noticeable problem would be a slower site than we have now.
Much of the information needed for a remote starter install is also needed for an alarm or keyless entry install and vice versa and most of the time when someone is installing a remote starter, they are also installing an alarm or keyless entry, or they are adding the remote starter to an existing alarm or keyless entry. When members include all the security information they have when they reply to a post in the car security forum, even if it is more than what was requested or needed to answer the original post, it helps other members that are doing a similar install in the same vehicle.
The solution and what would be helpful to all members is if members would be more specific when creating new topics instead of being so vague as many (not all) have been.
Examples:
"99 Ford Explorer remote start " versus "99 ford explorer"
"99 Ford Explorer stereo diagram" versus "i need a diagram for a 99 ford explorer"
dedicated remote starter forum -- posted image. the12volt • Support the12volt.com
defective
Silver - Posts: 642
Posted: November 15, 2003 at 11:53 AM / IP Logged
Thanx for the reply.. I understand
the12volt
Posted: November 15, 2003 at 12:05 PM / IP Logged
You're welcome ;)
defective
Silver - Posts: 642
Posted: November 15, 2003 at 1:29 PM / IP Logged
how about an ignition bypass forum....laugh. I can keep dishin' em out if you keep replying....grin
the12volt
Posted: November 15, 2003 at 1:33 PM / IP Logged
Thanks, but no thanks.
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
