2007 chevy trailblazer alarm wiring
raulromo34
Member - Posts: 28
Posted: December 19, 2007 at 3:44 PM / IP Logged
i am installing an standard alarm with power locks in a 2007 chevy trailblazer.  i have the dei-1700g passlock and doorlock interface module.  i need the the wiring diagram for the vehicle.  does anyone have it???  thanks  raul
football fanatic
Twelvoltz
Platinum - Posts: 2,384
Posted: December 20, 2007 at 7:29 AM / IP Logged
Audiovox Lists:
          #513906: 2007 CHEVROLET TRAILBLAZER 4DR SUV SS WITH 6.0L ENGINE AND STANDARD AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          ORANGE          (+)          RADIO HARNESS
     Accesory          ORANGE          (DATA)          RADIO HARNESS
               THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE.
     Ground          BLACK/ WHITE          (-)          RADIO HARNESS
     LF Speaker (+)          TAN
               THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER
     LF Speaker (-)          GRAY
     RF Speaker (+)          LIGHT GREEN
               THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
     RF Speaker (-)          DARK GREEN
     LR Speaker (+)          BROWN
     LR Speaker (-)          YELLOW
     RR Speaker (+)          DARK BLUE
     RR Speaker (-)          LIGHT BLUE
     Steering Cntrls          OPTIONAL
               THIS VEHICLE MAY BE EQUIPPED WITH ONSTARŪ AND MAY LOSE DOOR CHIME AND OTHER VEHICLE MONITORING FUNCTIONS WHEN OEM RADIO IS REPLACED. USE PROPER INTEGRATION PIECE TO MAINTAIN THESE FEATURES.
     Speed Cntrl          OPTIONAL
     Radio Security          YES
     Security
     Battery          RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          PINK          (+)          IGNITION SWITCH HARNESS
     Starter 1          YELLOW          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          GRAY/BLACK          (+)          AT VEHICLE REAR FUSEBOX UNDER LEFT REAR SEAT
               TO AVOID THE DOMELIGHT DELAY FUNCTION, USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE,
     Domelight Super          GRAY/BLACK          (+)          AT VEHICLE REAR FUSE BOX UNER REAR LEFT SEAT
     LF Latch          GRAY/BLACK          (-)          DRIVER DOOR MODULE IN DRIVER DOOR
     RF Latch          BLACK/ WHITE          (-)          PASSENGER DOOR MODULE IN PASSENGER DOOR
     LR Latch          LIGHT BLUE/BLACK          (-)          AT VEHICLE REAR FUSE BOX UNDER REAR LEFT SEAT
     RR Latch          LIGHT GREEN/ BLACK          (-)          AT VEHICLE REAR FUSE BOX UNDER REAR LEFT SEAT
     Trunk Trigger          PINK/BLACK          (-)          AT MODULE IN REAR HATCH
               VIOLET (-) WILL MONITOR THE GLASS AT THE MODULE IN THE REAR HATCH
     Hood Trigger          PINK/BLACK          (-)          AT VEHICLE HOOD PIN SWITCH
               NOT ON ALL MODELS
     Alarm Disarm          LIGHT GREEN/ BLACK          (-)          IN DRIVERS DOOR AT MODULE
     Parking Lights          BROWN          (+)          AT VEHICLE FUSEBOX UNDER REAR LEFT SEAT
     Low Crr Pk Lights          GRAY/BLACK          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     Data Bus          ORANGE          (DATA)          RADIO HARNESS
     Convenience
     Headlights-Lo          WHITE          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     LF Pk Lt Bulb          BROWN          (+)          AT FRONT LEFT PARKING LAMP
     RF Pk Lt Bulb          BROWN          (+)          AT FRONT RIGHT PARKING LAMP
     LR Pk Lt Bulb          BROWN          (+)          AT REAR LEFT TAIL LIGHT ASSEMBLY
     RR Pk Lt Bulb          BROWN / WHITE          (+)          AT REAR LEFT TAIL LIGHT ASSEMBLY
     All Hazrd Lights          WHITE          (-)          AT VEHILCE HAZARD SWITCH
     LF Hazrd Bulb          LIGHT BLUE          (+)          AT FRONT LEFT TURN LAMP
     RF Hazrd Bulb          DARK BLUE          (+)          AT FRONT RIGHT TURN LAMP
     LR Hazrd Bulb          LIGHT BLUE          (+)          AT REAR LEFT TAIL LIGHT ASSEMBLY
     RR Hazrd Bulb          DARK BLUE          (+)          AT REAR RIGHT TAIL LIGHT ASSEMBLY
     Wipers-Lo          PINK          (+)          AT VEHICLE WIPER CONTROL SWITCH
     Wipers-Hi          DARK BLUE          (-)          AT VEHICLE WIPER CONTROL SWITCH
     Parking Brake          LIGHT BLUE          (-)          AT VEHICLE PARKING BRAKE SWITCH
     Seat Mem 1          WHITE          (+)          AT MODULE IN DRIVER DOOR
     Seat Mem 2          VIOLET          (+)          AT MODULE IN DRIVER DOOR
     Remote Start
     Ignition 2          WHITE          (+)          IGNITION SWITCH HARNESS
     Accessory 1          ORANGE          (+)          IGNITION SWITCH HARNESS
     Accessory 2          BROWN          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          GM PASSLOCK IIŪ ANTI-THEFT SYSTEM
     Anti-Theft Descript          THE BCM MODULE MUST SEE A SPECIFIC RESISTANCE VALUE BEFORE THE VEHICLE WILL START PROPERLY
     Key Sense          LIGHT GREEN          (-)          IGNITION SWITCH HARNESS
     Tachometer          WHITE          (AC)          AT PCM MODULE ON DRIVER SIDE OF ENGINE
     Speed Sense          DARK GREEN / WHITE          (AC)          AT PCM MODULE ON DRIVER SIDE OF ENGINE
     Low Crr. Pk Lights          GRAY/BLACK          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     Brake Lights          WHITE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          LIGHT GREEN          (+)          AT VEHICLE REAR FUSE BOX UNDER REAR LEFT SEAT
     Horn          BLACK / YELLOW          (-)          IN HARNESS AT STEERING COLUMN
               ALSO BLACK (-) AT BCM MODUEL UNDER REAR LEFT SEAT
     Modules
     WIRE          LOCATION
     Module 1          BCM MODULE-UNDER REAR LEFT SEAT
     Module 2          REAR FUSE BOX- UNDER REAR LEFT SEAT
     Module 3          ECM/PCM- ON DRIVER SIDE OF ENGINE UNDER HOOD
     Module 4          EBCM- FRONT DRIVER SIDE FRAME RAIL
     Doorlocks/Windows
     Databus Wire          ORANGE          (DATA)          RADIO HARNESS
     Power Unlock          GRAY          (REV)          AT MOTOR IN DOORS
               THE DOOR LOCKS IN THIS VEHICLE ARE MULTIPLEXED. WIRE AS A REVERSING POLARITY SYSTEM IN EACH FRONT DOOR OR ACQUIRE A MULTIPLEX INTERFACE ADAPTER FROM A SECURITY MANUFACTURER.
     PowerLock          TAN          (REV)          AT MOTOR IN DOORS
     Driver Mtr Unlock          TAN          (REV)          AT MOTOR IN DOOR
     Driver Mtr Lock          GRAY          (REV)          AT MOTOR IN DOOR
     Pas Mtr Unlock          TAN          (REV)          AT MOTOR IN DOOR
     Pas Mtr Lock          GRAY          (REV)          AT MOTOR IN DOOR
     LF Window Up          DARK BLUE          (REV)          DRIVER DOOR MODULE
     LF Window Dn          BROWN          (REV)          DRIVER DOOR MODULE
     RF Window Up          LIGHT BLUE          (REV)          PASSENGER DOOR MODULE
     RF Window Dn          TAN          (REV)          PASSENGER DOOR MODULE
     LR Window Up          DARK BLUE          (REV)          REAR LEFT WINDOW SWITCH IN REAR LEFT DOOR
     LR Window Dn          BROWN          (REV)          REAR LEFT WINDOW SWITCH IN REAR LEFT DOOR
     RR Window Up          DARK BLUE          (REV)          REAR RIGHT WINDOW SWITCH IN REAR RIGHT DOOR
     RR Window Dn          BROWN          (REV)          RERA RIGHT WINDOW SWITCH IN REAR RIGHT DOOR
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
