Bypass Grand Cherokee alarm
Jpbydx
Posted: February 25, 2003 at 7:42 PM / IP Logged
HI all. New here. How do I bypass or disconnect the factory alarm on a 93 Jeep Grand Cherokee Limited. Alarm won't let the jeep start.
TIA.
78 CJ7, 93 ZJ Limited, 98 ZJ 5.9, 94 RX-7 TT
jayts95
Copper - Posts: 150
Posted: February 25, 2003 at 7:59 PM / IP Logged
|FCTRY ALRM DISARM|purple / YELLOW       |- |driver kick,black plug
Jpbydx
Posted: February 25, 2003 at 8:25 PM / IP Logged
jayts95 Thanks. Do I need to groung it or just cut it?
ViperATC5
Copper - Posts: 202
Posted: February 25, 2003 at 10:29 PM / IP Logged
the wire needs to receive a (-) output when the unit attempts to remote start. Your remote start should come with a factory alarm disarm wire that will supply the negative output. Do not cut or ground this wire in the vehile, simply connect the disarm output from the remote start unit to this wire
Jpbydx
Posted: February 26, 2003 at 12:58 PM / IP Logged
ViperATC5 - Thanks, but I'm not trying to install a remote starter. I need to kill the factory alarm because it's all messed up and won't let the Jeep start. How can I connect a negative output to that wire?
Platinum - Posts: 12,488
Posted: February 26, 2003 at 4:52 PM / IP Logged
Just ground the wire permanently and the OEM alarm will not activate until the ground is lifted.
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
