reverse light wires
jbattagl
Posted: January 05, 2008 at 6:49 AM / IP Logged
Hello,
I'm looking for a wire diagram for the reverse lights for a 98 Grand Prix GT. The reverse lights aren't working because the battery leaked, but I can't find where the wires are fried. Any help is greatly appreciated.
Thanks in advance,
John
KarTuneMan
Platinum - Posts: 7,056
Posted: January 05, 2008 at 9:28 AM / IP Logged
Your battery "leaked" or died? Either way, most likely not the problem. I'm sure your wires aren't fried anywhere. It's a switch, a bad ground, or a voltage issue. (or toasted bulbs)
You need to get your meter out and do some testing. Ckeck continuity on the bulb first. (to see if the bulb is toast)
Fuses?
jbattagl
Posted: January 05, 2008 at 11:02 AM / IP Logged
Hello KarTuneMan,
Thanks for your Post. Unfortunately it definitely is a fried wire as Pontiac has fixed this before and told me of the problem but didn't point the wire out to me. Do you have a diagram by any chance?
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
