2006 ford 500 limited wiring diagram
eightn9ne
Posted: January 07, 2008 at 2:33 PM / IP Logged
Looking for the wiring diagram for this vehicle is it the same as the taurus?  Specifically I am looking for a 12v accessory wire to tap into under the drivers side dash if possible.
Thanks For any help
mikvot
Gold - Posts: 1,043
Posted: January 07, 2008 at 8:48 PM / IP Logged
Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS RED / orange Bottom of fusebox on right of parking brake   +
 IGNITION Lt. GREEN/ purple Ignition harness   +
 ACCESSORY Gray / YELLOW Ignition harness   +
 STARTER Dk. Green Ignition harness   +
 KEY SENSE Yellow Ignition switch harness   +
 TACH SIGNAL Opposite from Red At any of the ignition coils on the engine   AC
 FUEL INJECTOR Opposite from Red At any injector on engine   AC
 LOCK Pink / YELLOW Driver kick panel   -
 UNLOCK Pink/Lt. green Driver kick panel   -
 DOORPIN BLACK/ blue In driver's front side pillar or kickpanel   +
 HOODPIN Violet/orange At pin under hood   -
 TRUNK PIN WHITE/ violet In driver's kickpanel   -
 TRUNK RELEASE Pink/orange At release switch in dash   -
 FACTORY ARM Arms with lock wire
 FACTORY DISARM Lt.blue/black In driver's kickpanel   -
 BRAKESWITCH RED / green At switch above brake pedal   +
 PARKLIGHTS BROWN / white In driver's kickpanel   +
 PARKLIGHTS (-) BLACK/ green At light switch harness   -
 HAND BRAKE RED / yellow At switch on handbrake lever   -
 HORN Dk. Blue Steering column harness   -
 HEADLIGHTS RED / white At light switch harness   -
 REVERSE LIGHTS WHITE/ yellow In driver's kickpanel   +
