2003 dodge stratus
bad_az_s10
Member - Posts: 8
Posted: February 25, 2003 at 11:50 PM / IP Logged
I need an alarm diagram for a 2003 stratus... Or is it the same as a 2000....Any help on this matter would be appreciated...thanx
Trucks, Sex, And NO REGRETS!
Moderator - Posts: 12,488
Posted: February 26, 2003 at 5:19 AM / IP Logged
Coupe ? Convertible ? Sedan ?
bad_az_s10
Member - Posts: 8
Posted: February 26, 2003 at 1:32 PM / IP Logged
4- door sedan w/ pdl pw and at
thank you
Posted: February 26, 2003 at 4:50 PM / IP Logged
|              12V|pink/black & red    |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|blue                |+  |ignition harness            |
|  SECOND IGNITION|GREEN/ red (20awg)   |+  |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ white         |+  |ignition harness            |
|       POWER LOCK|WHITE/ green         |*1 |conn. C4, pin 15 @ BCM *2   |
|     POWER UNLOCK|same                |*1 |same                        |
|       LOCK MOTOR|ORANGE / black        |   |conn. C4, pin 9 @ BCM *2    |
|     UNLOCK MOTOR|blue/white          |   |conn. C4, pin 13 @ BCM *2   |
|    DISARM DEFEAT|pink/lt. blue       |   |conn. C4, pin 25 @ BCM *2   |
| PARKING LIGHTS +|BLACK / YELLOW        |   |headlight switch or DKP     |
|       HEADLIGHTS|PURPLE / white        |+  |headlight switch            |
|     DOOR TRIGGER|*3                  |-  |BCM *2                      |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|tan/black           |-  |conn. C4, pin 18 @ BCM *2   |
|TRNK/HTCH RELEASE|BLACK/ white         |5wi|conn. C4, pin 1 @ BCM *2    |
|  FCTRY ALARM ARM|lt. GREEN/ orange    |*4 |conn. C4, pin 4 @ BCM *2    |
|FCTRY ALRM DISARM|same                |*4 |same                        |
|       TACHOMETER|*5                  |   |*5                          |
|      SPEED SENSE|WHITE/ orange        |8  |conn. C2, pin 66 @ PCM *6   |
|       BRAKE WIRE|WHITE/ tan           |+  |brake pedal switch          |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
|           WIPERS|brn/wht, RED / yel    |+  |wiper motor                 |
|  LF WINDOW UP/DN|lt. blue - white    |A  |drivers window switch       |
|  RF WINDOW UP/DN|brn/wht - pur/wht   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|blu/wht - RED / blk   |A  |drivers kick panel          |
|  RR WINDOW UP/DN|gry/blk - grn/wht   |A  |drivers kick panel          |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|pink                |+  |radio                       |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|RED / white           |+  |radio                       |
| RADIO ILLUMINATE|ORANGE / brown        |+  |radio                       |
|       LF SPEAKER|green - brn/red     |   |radio                       |
|       RF SPEAKER|purple - blu/red    |   |radio                       |
|       LR SPEAKER|brn/yel - brn/lt blu|   |radio                       |
|       RR SPEAKER|blu/wht - blu/org   |   |radio                       |
Notes:
NOTE: Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting.   *1 Lock is positive thru a 1800 ohm resistor, unlock is positive thru a 750 ohm resistor. Must use relays.  *2 The BCM is attached to the fuse/relay box at the end of the dash on the driver side. Connector C4 is a 26 pin plug on the bottom edge of the BCM.  *3 All the door triggers are in connector C4 at the BCM. The drivers door trigger is tan in pin 5, the front passenger door is tan/red in pin 6, the left rear door is tan/orange in pin 7, and the right rear door is tan / YELLOW in pin 8. Use all four and diode isolate each.  *4 Arm is positive trigger thru a 1800 ohm resistor, disarm is positive thru a 750 ohm resistor. Must use relays.  *5 For tach go to either a coil or an injector and use the wire that is NOT GREEN/ lt. green.  *6 The PCM is between the air filter box and the power distribution box on the driver side of the engine compartment.
