1998 expedition amp n sub
lkinzle
Posted: January 13, 2008 at 6:19 PM / IP Logged
We recently purchased a 1998 for expedition, and we are lookin into putting in my 15" sub, and my amp. Well when opened back side door panel, found a 8" sub w amp. Well sub was blown so we just disconnected it, well he went to cut wires, and now the stereo will only play thru headphones from the middle seats. He says he hooked all wires back up like they were, checked the fuses, but still wont work. Are we missing where there is a fuse box that maybe he needs to check out? What is causing only the headphones to work? We have no sound period thru speakers.. We do not have a manual for it, there for some reason was not one with the vehicle when we got it.. Where else in the vehicle woudl there be a fuse box to check? Does anyone have any idea as to what he might need to do???????????? Thanks
Platinum - Posts: 13,726
Posted: January 13, 2008 at 8:26 PM / IP Logged
There is a fuse for that amp, it is in the fuse box under the hood.
lkinzle
Posted: January 14, 2008 at 6:51 AM / IP Logged
Yes, he said he looked at the ones under the hood, none of them were blown.. We were told of a website that we are gonna check out that gives diagram of where all fuse boxes are in the vehicles.. Thanks
KPierson
Platinum - Posts: 3,527
Posted: January 14, 2008 at 7:50 AM / IP Logged
Did he look at them or did he test them?  Many people actually overlook blown fuses because they miss a hairline crack in the element.  It's always a good idea to use a meter, or just replace the suspect fuse.
Kevin Pierson
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
