buick dimmer lights
thugslife
Posted: March 06, 2008 at 9:48 PM / IP Logged
does any body know why the dimmer lights  of a buick 96 lesabre would go out when doing a radio install??     also if you do how to fix it and at least the wiring diagrams for the dimmer lights schematic
Beast of Rage
KarTuneMan
Platinum - Posts: 7,056
Posted: March 07, 2008 at 12:35 AM / IP Logged
The problem more than likely is not the switch. There is a mistake behind the radio. Check on the radio harness the dimmer and illumination.
12V DC Battery(Constant)Orange Miscellaneous, radio & cluster fuse 9C 10 amp In-panel fuse block
Switched AccessoryYellow  8D 10 amp In-panel fuse block
Ground Black Pins F8, F9 & E16
Power Antenna Dark green
Illumination Gray & yellow
Dimmer PURPLE / white
Steering Wheel Control Wire Light green
Left Front + Tan
Left Front - Gray
Right Front + Light green
Right Front - Dark green
Left Rear + Brown
Left Rear - Yellow
Right Rear + Dark blue
Right Rear - Light blue
