'02 Mustang Parklight Wire?
Sonic2002GT
Member - Posts: 7
Posted: March 05, 2003 at 8:15 PM / IP Logged
I'm sure someone out there has installed an alarm on a '99+ Mustang.  I would be VERY grateful if you could tell me where the brown parking light wire is.  I know it's supposed to be on the drivers side kick panel area, but  I've looked for about two hours, cut open every loom, pulled out all the plugs, but can't find it.  I was going to try to go straight to the switch, but can't seem to get the knob off to remove that panel, so if anyone has any experince with this particular car, I would be VERY appriciative!  Thanks!
draasch
Gold - Posts: 2,172
Posted: March 10, 2003 at 9:59 PM / IP Logged
read through the notes and you will find the parking light note
Constant 12 volts YELLOW (3) GRN/VIO (2) IGNITION SWITCH HARNESS
Ignition 12 volts RED / LIGHT GREEN IGNITION SWITCH HARNESS
Starter WHITE/ PINK IGNITION SWITCH HARNESS
Dome Light YEL/BLK(DR) GY/RD(PS) AT GEM MODULE * SEE TECH NOTES ***
Trunk Pin Switch LIGHT GREEN/ ORANGE (+) AT LIGHT IN TRUNK OR GEM MODULE *
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH OR GEM MODULE *
Power Lock PINK / YELLOW 14 PIN CONNECTOR HIGH **
Power Unlock PINK/L GREEN IN PASS KICK #202
* Generic Electronic Module Is Located Behind Driver Dash Above Brake Pedal. ** Doorlock Wires Can Also Be Found As LIGHT GREEN (+) For Lock And VIOLET (+) For Unlock At Grey 18 Pin Connector In Driver Kick Panel #202 - See Positive Pulse Door Lock DiagramParking Lamp BROWN (+) AT HEADLIGHT SWITCH OR GEM MODULE * Parking Lamp BROWN (+) AT HEADLIGHT SWITCH OR GEM MODULE *
Sonic2002GT
Member - Posts: 7
Posted: March 11, 2003 at 6:50 PM / IP Logged
DRAASCH, Thank you for your help, unfortunatly, as I put in my original post  "I know it's supposed to be on the drivers side kick panel area"  I know where it's SUPPOSED to be, I wanted to know if someone could tell me where it actually is.  BTW, I finally figured out WHY I couldn't find the brown wire... Cause it ISN'T BROWN!!  Darn thing is a really ugly gray...  I finally got the pull type light switch off (Which for the record, if anyone finds this in a search trying to get the spedo bezel appart, you have to remove the drivers side vent face and assembly, then squeeze your hand up to the switch, and there is a small button on the left hand side which you have to push (VERY HARD) while pulling the knob out, it will eventually come out, I just hope you have a smaller hand than I) so I finally got this taken care of, I just wish Ford's idea of brown really was brown :\
