need 08 odyssey wiring diagram
gofis
Posted: June 10, 2008 at 3:10 PM / IP Logged
Found wiring diagram for 06 only. Is 08 the same (08 Honda Odyssey)
kola7126
Copper - Posts: 93
Posted: June 11, 2008 at 4:02 AM / IP Logged
 MODEL YEAR(S)
 ODYSSEY  2005 -2008
 KEY T-HARNESS IMMOBILIZER
  N/A   N/A   HONDA'S TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY
 PART  COLOR LOCATION
 12 VOLT CONSTANT  WHITE (+)   IGNITION SWITCH HARNESS
 STARTER BLACK/ WHITE (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 BLACK / YELLOW (+)  IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 BLACK/ RED (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 WHITE/ RED (+)  IGNITION SWITCH HARNESS
 KEYSENSE N/A
 PARKING LIGHTS ( - ) RED / BLACK (-)  @ HEADLIGHT SWITCH, in COLUMN COVER
 PARKING LIGHTS ( + ) RED / BLACK (+)  @ DRIVER FUSE/RELAY BOX, 17-Pin Plug
 POWER LOCK PINK/BLACK (TYPE B)  IN PASSENGER KICK PANEL, at DOOR HARNESS
 POWER UNLOCK GREEN (TYPE B)  IN PASSENGER KICK PANEL, at DOOR HARNESS
 DOOR TRIGGER YELLOW (-)  @ INTERIOR LIGHT SWITCH on DASH
 DOMELIGHT SUPERVISION BLACK/ RED (-), Requires Part #775 Relay  @ INTERIOR LIGHT SWITCH on DASH
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN GREEN/ YELLOW (-)  @ HORN SWITCH
 TACH Any wire NOT YELLOW/BLACK  @ FUEL-INJECTOR
 WAIT TO START LIGHT N/A
 BRAKE WHITE/ BLACK (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  BLACK/ RED to WHITE (-)  @ DRIVER DOOR MODULE IN DRIVERS DOOR
 ANTI-THEFT TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY  TRANSPONDER @ IGNITION SWITCH TUMBLER
gofis
Posted: June 11, 2008 at 10:52 PM / IP Logged
thanx
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
