2004 bmw 745 li remote start
frank_30
Member - Posts: 26
Posted: June 23, 2008 at 1:48 PM / IP Logged
need wiring for 2004 BMW 745 li  for remote start ?? help
"throw it in the gutter and go buy another"
kola7126
Copper - Posts: 93
Posted: July 01, 2008 at 10:55 AM / IP Logged
POWER SUPPLY +30: connect directly to the big wire coming out of the battery terminal. It is suggested such connection
as some connections with fixed supply are deactivated by the electronic system of the vehicle after about
30 min. from the extinction of the switchboard.
-31: connect with a cable terminal directly to the ground terminal located behind the driver’s side sill
cover.
IGNITION WIRE +15/54: connect to the BLACK/ RED wire, at the position nr. 19 coming out of the 32 way black connector
of the “battery cut out” central, in the passenger’s side boot. As alternative connect to the 1,5mm2
GREEN/ BLUE wire located in the wiring harness behind the driver’s side sill cover.
DIRECTION INDICATORS Connect to the wires: BLUE/GREEN pos. nr.4 for the driver’s side ant. direction indicator,
BLUE/BROWN pos. nr.1 for the passenger’s side rear direct. indic., BLUE/BROWN pos. nr.24 for the
passenger’s side ant. direct. indic., BLUE/GREEN pos. nr.55 for the driver’s side rear dir. indic., located
in the 88 way black connector coming out of the lights operating central located on the left of the steering
column. It is suggested to separate the lines by means of 4 diodes.
ELECTRIC WINDOWS Positive control signal
Doors and windows Comfort locking
Connect to the BLUE/RED wire at the position nr.7 (lock) and to the WHITE/ BLACK wire at the position
nr.9 (unlock), located in a 18 way black connector, directly on the coming out of the push-button panel
inside the driver’s side door.
CENTRAL DOORS LOCKING Negative control signal
Connect with both the (VIOLET and ORANGE) wires of the antitheft to the YELLOW/RED wire at the
position nr.24, of the 26 way white connector, directly coming out of the central locking unit located
behind the passenger’s side glove compartment
IMMOBILISATION POINT 1 Gasoil pump
Cut the BLUE/BLACK wire, in the 13 way black connector, of the white central located behind the
passenger’s side glove compartment.
IMMOBILISATION POINT 2 General ignition wire
Cut the BLACK / YELLOW wire in the connector coming out of the ignition key.
STARTER +50: Cut the 2mm2 BLACK wire located in the wiring harness coming out of the MOTRONIC central
placed in the lower part of the antipollen filter, in the engine compartment.
BONNET SWITCH Connect to the wire coming out of the lamp directly in the bonnet/engine.
DOORS SWITCH NOTE: the polarity is positive. Invert the signal with an additional relay. Connect to the RED / BLUE wire
located in the wiring harness coming out of the lamp of the driver’s side rudder pedals. As alternative: at
the position nr.20, in a black connector of the white central located behind the passenger’s side glove
compartment.
BOOT SWITCH Connect to the YELLOW/BLACK wire, at the position nr.19, of the 26 way white connector, directly
coming out of the white central placed behind the passenger’s side glove compartment.
X
frank_30
Member - Posts: 26
Posted: July 01, 2008 at 11:04 AM / IP Logged
cover.
compartment.
X
Thank you ,had no help on this vehicle seem like no one likes to touch these! :) Thanks Again.
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
