2005 Pontiac Grand Flasher Relay Location
sever.gp
Posted: July 11, 2008 at 7:43 PM / IP Logged
Can anyone tell me the location of the Flasher relay unit in a 2005 Pontiac Grand Prix. Thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: July 20, 2008 at 1:34 AM / IP Logged
What is it you are trying to do?
wrenchcat
Posted: July 20, 2008 at 6:50 PM / IP Logged
Hi...Not certain about a 2005 but, on the 2004 Grand Prix i did last week it was attached to the hazard flasher button. I had to pull the trim ring around the flasher unit which is located in the center of the dash, and the flasher unit came with the trim ring. just pull the 2 plastic clips back and the flasher/hazard unit comes out. Very easy.I bought a new unit from the dealer for $35.Which, by the way, didn't solve the problem. Which was the blinkers were messed up. To repair the problem i had to replace the blinker switch unit.
Hope that helps!   ^_^
wrenchcat
