2003 caravan hatch release
nikko
Member - Posts: 7
Posted: March 09, 2003 at 10:02 AM / IP Logged
I installed a hatch release into a doge caravan 2003 but the release only works with key inserted into the lock cylinder. Anyone have any suggestions. Thank you
Platinum - Posts: 12,488
Posted: March 09, 2003 at 4:13 PM / IP Logged
Did you wire the hatch to a constant power source or just an IGN power ? If you used an IGN then you have to change it to a constant for it to work without the key in the cylinder.
nikko
Member - Posts: 7
Posted: March 10, 2003 at 9:06 PM / IP Logged
I connected it to a constant 12v. I meant the had to be put into the hatch lock cylinder not the ign.
