93 civic si alternator
twobig86
Copper - Posts: 84
Posted: September 24, 2008 at 8:31 AM / IP Logged
1993 honda civic si 2 door coupe. 1.6L Manual.
I am getting custom brackets made for my 300 A custom alternator made by Dominik Iraggi.  This alternator has a positive terminal which I was told goes directly to battery and one brown wire which he told me is the ignition wire.  My only problem with this is I don't know where this wire goes...
I looked up the vechicle wiring database on this site and under the alarm, remote starter, keyless entry wiring information I found this...
Constant 12V+White Ignition Switch Harness
StarterBLACK/ White Ignition Switch Harness
IgnitionBLACK / YELLOW Ignition Switch Harness
AccessoryYellow Ignition Switch Harness
Is that Ignition wire the one I want to connect the alternator wire too?  Also where is this located in my car?  Lastly what does it do for the alternator?
Thanks, Michael
Platinum - Posts: 13,726
Posted: September 25, 2008 at 8:58 AM / IP Logged
There should be an ignition wire on the plug for your old alternator.   Use it.
twobig86
Copper - Posts: 84
Posted: September 25, 2008 at 12:03 PM / IP Logged
Where would I be able to get a wiring diagram of the alternator?
