06 lexus ls430 alarm/autostart wiring
Welcome Guest :)
sonicjj
Member -
Posted: September 30, 2008 at 5:18 PM / IP Logged
I need the alarm and autostart wiring info for a 2006 Lexus LS430 with the transponder key and pushbutton start.
THANKS !
kola7126
Copper -
Posted: October 06, 2008 at 4:45 PM / IP Logged
| MODEL | YEAR(S) |
| LS430 | 2004 -2007 |
| KEY | T-HARNESS | IMMOBILIZER |
| N/A | N/A | LEXUS TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 Bypass Module and extra Ignition Key |
| PART | COLOR | LOCATION |
| 12 VOLT CONSTANT | Connect to BATTERY ONLY | |
| STARTER | BLACK/ WHITE (+) | IGNITION SWITCH HARNESS |
| STARTER 2 | N/A | |
| IGNITION 1 | GREEN/ YELLOW (+) | IGNITION SWITCH HARNESS |
| IGNITION 2 | RED / WHITE (+) | IGNITION SWITCH HARNESS |
| IGNITION 3 | N/A | |
| ACCESSORY /HEATER BLOWER 1 | WHITE/ GREEN (+) | IGNITION SWITCH HARNESS |
| ACCESSORY /HEATER BLOWER 2 | N/A | |
| KEYSENSE | LIGHT GREEN/ BLACK (-) | IGNITION SWITCH HARNESS |
| PARKING LIGHTS ( - ) | ORANGE (-) See NOTE *1 | @ HAZARD SWITCH |
| PARKING LIGHTS ( + ) | N/A | |
| POWER LOCK | RED / BLACK or PURPLE / RED (TYPE B) See NOTE *2 | @ ECU, INSIDE DRIVERS DOOR |
| POWER UNLOCK | BLACK/ GREEN (TYPE B) See NOTE *2 | @ ECU, INSIDE DRIVERS DOOR |
| DOOR TRIGGER | PINK/GREEN (-) and BLUE (-) Use both, See NOTE *3 | @ ECU, INSIDE DRIVERS DOOR |
| DOMELIGHT SUPERVISION | PURPLE / WHITE (-) | @ IGNITION KEY CYLINDER LIGHT |
| TRUNK RELEASE | PURPLE (-) | @ 22-PIN PLUG, IN DRIVERS KICK PANEL |
| SLIDING POWER DOOR | N/A | |
| HORN | N/A | |
| TACH | BLACK / YELLOW | @ PIN 9, IN DATA LINK CONNECTOR UNDER DASH |
| WAIT TO START LIGHT | N/A | |
| BRAKE | GREEN/ ORANGE (+) | @ SWITCH ABOVE BRAKE PEDAL |
| FACTORY ALARM DISARM | DISARMS with KEYSENSE wire | See NOTE *4 |
| ANTI-THEFT | TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY | TRANSPONDER @ IGNITION SWITCH TUMBLER |
| EXTRA INFORMATION |
| NOTE *1 USE HAZARD WIRE, IT'S ORANGE (-) IN 10-PIN PLUG AT DRIVERS FUSEBOX. NOTE *2 TEST THE LOCK AND UNLOCK WIRES WHILE TURNING KEY IN THE DRIVERS DOOR KEY CYLINDER. NOTE *3 THE FRONT DOOR TRIGGERS ARE PINK/GREEN (-) AT EACH DOOR MODULE,THE REAR DOOR TRIGGERS ARE BLUE (-) AT EACH DOOR MODULE. WHEN CONNECTING TO AN ALARM SYSTEM, USE ALL 4 DOOR TRIGGER WIRES AND DIODE ISOLATE, TO CONNECT, SEE DIAGRAM. NOTE *4 the vehicle can be disarmed without unlocking by attaching a (-) Negative output wire to the LIGHT GREEN/ BLACK (-) KEYSENSE wire in the IGNITION SWITCH HARNESS. |
Tuesday, February 17, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
