08 taurus add on alarm
campinout
Member - Posts: 16
Posted: October 07, 2008 at 11:47 AM / IP Logged
looking for info on wiring for 08 taurus. having problems finding the keyless only wiring for an add on alarm; the wires that control only the keyless and not just the door switches. been thru audiovox wiring to no avail.
Old School Funkster
silent4408
Member - Posts: 11
Posted: October 15, 2008 at 10:35 PM / IP Logged
     Unlock is yellow / purple and negative trigger
        Lock is Blue / green
heres the rest of the info on your car if u need it
2008 Ford Taurus      DirectWire 2.0 Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     red (80A)     +     SJB, 1 pin plug (G), pin 1
     The SJB (Smart Junction Box) is the fuse box under the driver side dash.
Second 12 Volts     red (20A)     +     ignition switch, 7 pin plug, pin 4
Starter     blue/white     +     ignition switch, 7 pin plug, pin 7
Second Starter     N/A
Ignition     WHITE/ orange     +     ignition switch, 7 pin plug, pin 1
Second Ignition     N/A
Third Ignition     N/A
Accessory     PURPLE / green     +     ignition switch, 7 pin plug, pin 6
Second Accessory     N/A
Third Accessory     N/A
Keysense     blue/gray     +     ignition switch, 7 pin plug, pin 5
Data Bus     yellow/orange (TX), PURPLE / gray (RX)     data     PATS Transceiver, 4 pin plug, pins 3 (TX), 4 (RX)
     The PATS (Passive Anti-Theft System) Transceiver is around the ignition key cylinder. The PATS ignition wire is blue/brown in pin 1 and the ground wire is BLACK/ blue in pin 2.
Can Bus High     gray/orange     data     data link connector under driver dash, pin 3
Can Bus Low     PURPLE / orange     data     data link connector under driver dash, pin 11
Can Bus Sw     N/A
Power Lock     blue/green     -     driver kick or SJB, 26 pin plug (C), pin 17
Power Unlock     yellow/purple     -     driver kick or SJB, 26 pin plug (C), pin 4
Lock Motor     gray/brown     5 wire     driver kick or SJB, 32 pin plug (D), pin 6
Driver Unlock Motor     blue/green     5 wire     driver kick or SJB, 32 pin plug (D), pin 28
Passenger Unlock Motor     PURPLE / gray     5 wire     driver kick or SJB, 32 pin plug (D), pin 27
Parking Lights (-)     gray     -     headlight switch or SJB, 52 pin plug (B), pin 31
     The SJB (Smart Junction Box) is the fuse box under the driver side dash. May need to interrupt the headlight switch ground wire when triggering this wire. It is BLACK/ blue at the headlight switch, 10 pin plug, pin 7. See Tech Doc 1096 for wiring information.
Parking Lights (+)     purple or PURPLE / white     +     driver kick or SJB, 32 pin plug (D), pin 20
Hazards     BROWN / yellow     -     hazard switch or SJB, 52 pin plug (B), pin 48
Turn Signal (Left)     blue/green (F); gray/brown (R)     +     SJB, 26 pin plug (F), pin 21; 32 pin plug (D), pin 25
Turn Signal (Right)     yellow/purple (F); PURPLE / orange (R)     +     SJB, 26 pin plug (F), pin 23; 32 pin plug (D), pin 26
Headlight     blue/white     -     headlight switch or SJB, 52 pin plug (B), pin 30
AutoLights     PURPLE / green     -     headlight switch or SJB, 52 pin plug (B), pin 50
Reverse Light     GREEN/ brown     +     driver kick, harness to rear
Left Front Door Trigger     GREEN/ purple     - N.C.     driver kick or SJB, 26 pin plug (C), pin 14
Right Front Door Trigger     white     - N.C.     passenger kick or SJB, 26 pin plug (C), pin 2
Left Rear Door Trigger     green     - N.C.     driver kick or SJB, 26 pin plug (C), pin 3
Right Rear Door Trigger     yellow     - N.C.     passenger kick or SJB, 26 pin plug (C), pin 15
Dome Supervision     gray/purple     +     driver kick or SJB, 14 pin plug (A), pin 9
     The SJB (Smart Junction Box) is the fuse box under the driver side dash. Also found in the driver A pillar. The exterior mirror puddle lamps wire is purple (+) in the driver kick, door harness or at the SJB, 26 pin plug (C), pin 12.
Trunk/Hatch Pin     gray/orange     - N.C.     driver kick or SJB, 26 pin plug (C), pin 16
Rear Glass Pin     N/A
Hood Pin     blue/orange     - N.C.     hood pin switch or SJB, 26 pin plug (F), pin 10
Trunk/Hatch Release     brown     -     release switch or SJB, 26 pin plug (C), pin 20
Trunk Release Motor     BROWN / blue     +     driver kick or SJB, 32 pin plug (D), pin 31
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     arms on lock with door open
Factory Alarm Disarm     GREEN/ purple     -     driver kick or SJB, 26 pin plug (C), pin 8
     Meter this wire while turning the key in the driver door key cylinder. The SJB (Smart Junction Box) is the fuse box under the driver side dash.
Disarm No Unlock     see factory alarm disarm
Trunk Alarm Shunt     N/A
Tachometer     NOT blue     ac     any fuel injector
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     N/A
Fuel Pump     PURPLE / green or PURPLE / white     +     inertia fuel shutoff switch in passenger kick
Rear Defroster     WHITE/ orange     - latched     HVAC Control Module in dash
     On vehicles with manual A/C, it is in the 26 pin plug (A), pin 3. On vehicles with automatic A/C, it is in the 26 pin plug (B), pin 23. Also found in a junction connector to the left of the steering column, pin 2.
Mirror Defroster     same as rear defroster
Left Front Heated Seat     WHITE/ blue          passenger kick or HVAC Module, 26 pin plug (B), pin 6
Right Front Heated Seat     gray / YELLOW          passenger kick or HVAC Module, 26 pin plug (B), pin 3
Speed Sense     BROWN / green     ac     PCM, plug towards driver side, pin 14
     The PCM (Powertrain Control Module) is under the hood, on the passenger side firewall.
Brake Wire     PURPLE / white     +     switch, dr kick, or SJB, 52 pin plug (B), pin 40
Parking Brake     WHITE/ purple     -     parking brake switch or SJB, 26 pin plug (C), pin 1
Horn Trigger     blue/white     -     horn switch or SJB, 52 pin plug (B), pin 41
Wipers     blue/orange (L), PURPLE / orange (H)     -     windshield wiper switch, 16 pin plug, pins 16 and 9
Left Front Window (Up/Down)     motor part of module
Right Front Window (Up/Down)     BROWN / yellow - GREEN/ orange     A     driver kick, door harness
Left Rear Window (Up/Down)     blue/orange - yellow     A     driver kick, door harness
Right Rear Window (Up/Down)     gray/purple - BROWN / green     A     driver kick, door harness
Sun Roof (Open/Close)     motor part of module
Sun Roof (Limit/Close)     N/A
Memory Seat 1     PURPLE / white     -     driver kick, harness to rear
Memory Seat 2     yellow     -     driver kick, harness to rear
Memory Seat 3     N/A
Radio 12V     WHITE/ red     +     radio, 24 pin plug, pin 1
Radio Ground     BLACK/ blue     -     radio, 24 pin plug, pin 13
Radio Ignition     blue     +     radio, 24 pin plug, pin 2
Radio Illumination     N/A
Factory Amp Turn-on     PURPLE / red (sub amp)     +     radio, 8 pin plug, pin 4
Power Antenna     YELLOW /GREEN     +     radio, 24 pin plug, pin 5
Left Front Speaker (+/-)     white - WHITE/ brown     +,-     radio, 24 pin plug, pins 8 and 21
Right Front Speaker (+/-)     WHITE/ purple - WHITE/ orange     +,-     radio, 24 pin plug, pins 11 and 12
Left Rear Speaker (+/-)     WHITE/ green - BROWN / yellow     +,-     radio, 24 pin plug, pins 9 and 22
Right Rear Speaker (+/-)     BROWN / white - BROWN / blue     +,-     radio, 24 pin plug, pins 10 and 23
Center Channel (+/-)     N/A
Subwoofer (+/-)     PURPLE / green - GREEN / WHITE     +,-     radio, 8 pin plug, pins 1 and 2
Aux. Audio Input Left (+/-)     blue - YELLOW /GREEN     +,-     radio, 16 pin plug, pins 7 and 8
Aux. Audio Input Right (+/-)     blue/green - WHITE/ green     +,-     radio, 16 pin plug, pins 6 and 14
RSE Video (+/-)
RSE Audio Left (+/-)     GREEN/ orange - blue/brown     +,-     radio, 16 pin plug, pins 1 and 2
RSE Audio Right (+/-)     PURPLE / brown - yellow/blue     +,-     radio, 16 pin plug, pins 9 and 10
Satellite Radio 12 Volts     blue/red     +     satellite radio receiver in driver side trunk
Satellite Radio Ground     BLACK/ blue     -     satellite radio receiver in driver side trunk
Satellite Radio Ignition     (CAN data bus)
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     GREEN/ orange - blue/brown     +,-     satellite radio receiver in driver side trunk
Satellite Audio Right (+/-)     PURPLE / brown - yellow/blue     +,-     satellite radio receiver in driver side trunk
Item     Size     Depth     Location
Headunit     double DIN          center of dash
Left Front Speaker     6 x 8          left front door
Left Front Tweeter     N/A
Right Front Speaker     6 x 8          right front door
Right Front Tweeter     N/A
Left Rear Speaker     6 x 8          left rear door
Left Rear Tweeter     N/A
Right Rear Speaker     6 x 8          right rear door
Right Rear Tweeter     N/A
Center Channel     N/A
Subwoofer     6 x 9 (x2)          rear deck
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner               driver side trunk
Smart Starter Kill Relay
Relay Type:
Part #:
OE Relay Part #:
n/a
n/a
n/a
Notes:
n/a
Alternate Part Notes:
n/a
Interface Modules
SKU     Module Description     Upgradeable     Keys Required for Programming     Keys Required for Operation
XK04     Programmable Platform #04: Ford PATS Override Interface / Firmware: PKFORD 3.00     Yes     2     0
556SW     FORD PATS3 SECURILOCK RF TRANSPONDER BYPASSKIT chip '01-08     No     2     0
© 2007 Directed Electronics. All Rights Reserved.
DirectWire and its vehicle information are for the sole use of authorized Directed Electronics personnel and it's participating dealers and distributors. The information contained on these pages may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited.
"JT" Advanced Certified installer for Sound Sensations in Marietta,GA
