2008 nissan qashqai wiring
hedders
Posted: October 24, 2008 at 1:16 PM / IP Logged
i am looking for the wiring diagram to install a remote engine start in my 2008 nissan qashqai irish model
Posted: October 24, 2008 at 1:30 PM / IP Logged
The others would know this as a "ROGUE".
hedders
Posted: October 24, 2008 at 4:33 PM / IP Logged
so does that mean i cannot get it???
Posted: October 24, 2008 at 4:53 PM / IP Logged
No, you do what a pro does, look for power supplies, grounding points, indicaters, lock system, ways through the bulkhead etc etc If you think you are not capable, get someone or a shop to do it for you. Remember even when we get crib sheets we check and test as we install. I did the almeira, you can do yours.
hedders
Posted: October 24, 2008 at 4:57 PM / IP Logged
can any one tell me the full wiring info for a 2008 nissan qashqai irish model...(ROGUE)???
hedders
Posted: October 24, 2008 at 4:59 PM / IP Logged
a i know i can do it it would jus be so much easier knowing were everytin is...thanx
Posted: October 24, 2008 at 5:43 PM / IP Logged
PM me with your email address, I'll send you the sheet on the 08 Rogue, the US version, remember if a unit is behind glovebox in the US it might be under dash here. I've looked at the crib sheet and it looks pretty straight forward, just remember to check the functions.
Saturday, November 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
