2002 ford econoline e 350, alarm/rs
jfbern
Posted: November 03, 2008 at 3:33 PM / IP Logged
Ford Econoline E-350 2002 please i need wiring color code
Platinum - Posts: 13,725
Posted: November 03, 2008 at 7:26 PM / IP Logged
For the entire vehicle?
jfbern
Posted: November 04, 2008 at 9:54 AM / IP Logged
Just for alarm and remote start installation please
Posted: November 04, 2008 at 8:15 PM / IP Logged
Remote Start
2002 ford econoline e 350, alarm/rs -- posted image.BatteryYELLOW(+)IGNITION SWITCH HARNESS
2002 ford econoline e 350, alarm/rs -- posted image.Ignition 1RED / LIGHT GREEN(+)IGNITION SWITCH HARNESS
2002 ford econoline e 350, alarm/rs -- posted image.Ignition 2BLACK/ LIGHT GREEN(+)IGNITION SWITCH HARNESS
2002 ford econoline e 350, alarm/rs -- posted image.Accessory 1GRAY / YELLOW(+)IGNITION SWITCH HARNESS
2002 ford econoline e 350, alarm/rs -- posted image.Starter 1WHITE/ PINK(+)IGNITION SWITCH HARNESS
2002 ford econoline e 350, alarm/rs -- posted image.Anti-Theft DescriptNONE
2002 ford econoline e 350, alarm/rs -- posted image.Key SenseBLACK/ PINK(-)STEERING COLUMN HARNESS
2002 ford econoline e 350, alarm/rs -- posted image.TachometerWHITE/ PINK(-)PCM DRIVERS REAR OF ENGINE 2 CYL SETTING
2002 ford econoline e 350, alarm/rs -- posted image.Speed SenseGRAY/BLACK(AC)DR.REAR OF ENG POS 58 OF PCM 104 PIN PLU
2002 ford econoline e 350, alarm/rs -- posted image.Parking LightsBROWN(+)LIGHT SWITCH
2002 ford econoline e 350, alarm/rs -- posted image.Brake LightsLIGHT GREEN(+)AT BRAKE SWITCH
2002 ford econoline e 350, alarm/rs -- posted image.Reverse LightsBLACK/ PINK(+)AT LIGHT
2002 ford econoline e 350, alarm/rs -- posted image.HornDARK BLUE(-)
AT STEERING COLUMN
Alarm Info
2002 ford econoline e 350, alarm/rs -- posted image.All Door TriggerBLACK/ BLUE(+)AT DOME LIGHT
2002 ford econoline e 350, alarm/rs -- posted image.Alarm DisarmGREEN/ VIOLET(-)THEFT MODULE OR DRIVERS KICK PANEL
2002 ford econoline e 350, alarm/rs -- posted image.Alarm ArmRED / YELLOW
jfbern
Posted: November 06, 2008 at 3:17 PM / IP Logged
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
