nissan sunny 2006 fusibles affectation
manaa
Member - Posts: 14
Posted: June 04, 2009 at 9:22 AM / IP Logged
hi
can any one give me the fusibles affectation on a 2006 nissan sunny.
also i need the wiring for keyless antry installation.
note: this model is also badged as sentra in usa and almera in europe (i think).
thank you in advance for any help.
Posted: June 04, 2009 at 11:13 AM / IP Logged
There's a body control box  like the BSI box on Peugeots adjacent to the steering column,  on it are lock/unlock, both neg, indicators (pos) and all door , trunk and possibly hood contacts.
t&t tech
Platinum - Posts: 2,622
Posted: June 04, 2009 at 6:12 PM / IP Logged
off the top off my head, door lock triggers are negative going, as howie said at the fusebok adjacent to the steering, to the bottom of it without removing the box, there runs the driver door harness, the colour wires are
lock- gray (thin gauge)
purple- unlock (thin gauge) they meter four volts or so at rest and go to ground or zero volts during lock and unlock
the actuator wires you can pick up in the driver floor panel
WHITE/ red- lock (thick gauge)
BLACK/ red- unlock
also in the floor panel you can pick up the door contacts- RED / white (light gauge)
trunk contact- RED / black (light gauge
hazards- GREEN/ black and GREEN/ YELLOW
brake- GREEN/ red
behind the fuse box you can pick up ignition BLACK/ red
and a constant either thick gauge red or white.
cheers.
t&t tech
Posted: June 04, 2009 at 6:14 PM / IP Logged
also howard, on this vehicle the interruption of the ignition also prevents the starter from turning. nissan sunny 2006 fusibles affectation -- posted image.
manaa
Member - Posts: 14
Posted: June 05, 2009 at 3:49 AM / IP Logged
thanks howieII and t&ttech
this box you said similar to BSI or UCH on french cars is located at the right of steering column at pasenger side ?
