2008 Ford Focus Alarm/Remote Start Wiring
Welcome Guest :)
sk8manpro3574
Member -
Posted: June 17, 2009 at 7:04 PM / IP Logged
Wiring diagram for a 2008 ford focus 2dr se. for remote start/alarm
Shawn
mikvot
Gold -
Posted: June 17, 2009 at 9:07 PM / IP Logged
| Wire/Function | Colour | Location/Description | Polarity |
| PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
| 12 VOLTS | Blue/red | Ignition switch harness | + |
| IGNITION | BROWN / yellow | Ignition switch harness | + |
| ACCESSORY | Violet/green | Ignition switch harness | + |
| STARTER | Blue/white | Ignition switch harness | + |
| KEY SENSE | Blue/gray | Ignition switch harness | + |
| TACH SIGNAL | Yellow/orange | At PCM near battery | AC |
| LOCK | Yellow/gray | In harness in driver kick panel | - |
| | | May also be Light Blue/Light Green (-) in driver's kick panel. |
| UNLOCK | Violet/brown | In harness in driver kick panel | - |
| | | May also be Yellow/Violet (-) in driver's kick panel. |
| DISARM | Violet/brown | In harness in driver kick panel | - |
| DRIVER LOCK MOTOR | Blue/green | In harness in driver kick panel | REV POL |
| DRIVER UNLOCK MOTOR | Gray/brown | In harness in driver kick panel | REV POL |
| DOMELIGHT / ALL DOORS | Gray/violet | In harness in driver kick panel | + |
| HOODPIN | Blue/orange | At smart junction box under driver dash | - |
| TRUNK PIN | YELLOW /GREEN | In harness in driver kick panel | - |
| TRUNK RELEASE | Light Blue | Driver's kick panel | + |
| | | Can use OEM remote to test. |
| BRAKE SWITCH | Violet/white | At switch above brake pedal | + |
| PARKING LIGHTS | Violet/white | At harness in driver's kick panel | + |
| HORN | Blue/white | Steering column harness | - |
Available Notes
| PLEASE NOTE: This vehicle is equipped with an IMMOBILIZER passive anti-theft system. Please refer to the ALARM diagram before any remote start installation. |
| Parking lights- Violet/white @ BCM above DKP. This wire should be used to avoid damage to the light switch. Trunk release- Brown next to lock wires. This wire will not test. |
Sunday, January 11, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
