drl module wiring for 05 altima
datboyvinh
Member - Posts: 7
Posted: June 23, 2009 at 9:54 PM / IP Logged
2005 Nissa Altima Se-r
i am trying to wire a DRL module into my 05 nissan altima but i need some help with locating certain wires, what and where is the:
high beam headlight output
Ignition  sense wire (what is a sense wire??)
low bean headlight sense
this is the instruction to the item i am trying to install to my car: http://www.hoppyonline.com/autoacc/inst/20013v2-1.pdf  its the < size=5 face=Verdana>Hopkins 20013VA Reduced Intensity Daytime Running Lights by DesignTech
Anthony
KPierson
Platinum - Posts: 3,527
Posted: June 23, 2009 at 10:01 PM / IP Logged
try:
www.nicoclub.com/FSM
Select your vehicle and look for an "LT.pdf" file.  All the wires regarding lighting should be there!
Kevin Pierson
datboyvinh
Member - Posts: 7
Posted: June 23, 2009 at 10:06 PM / IP Logged
yeah i was looking through that, the light section. i really do not know what i am looking for.
can you tell me what a sense wire is?
thanks
Anthony
KPierson
Posted: June 23, 2009 at 10:11 PM / IP Logged
The module has an "ignition sense" input - basically it's an input on the module that is just looking to see if the ignition is on.  It could also be called an Ignition input.
Kevin Pierson
datboyvinh
Member - Posts: 7
Posted: June 24, 2009 at 3:16 AM / IP Logged
are the 05 nissan altima a positive or negative headlight system? or neither?
In the positive systems the 12volts is switched to the headlight and the ground is constant.
In the negative systems the 12 volts is constant and the ground is switched.
KPierson
Posted: June 24, 2009 at 7:21 AM / IP Logged
Assuming the '06 is similar to the '05 (not sure why they don't have a manual for the '05) look at page 9 of the LT.pdf file I mentioned above - it shows the + outputs for all the lights.
The low beam sense would be either a RED / yellow or a blue wire at the IPDM (typically under the hood) and the high outputs would be blue/white and green (there are seperate outputs for each light).
If you go back up to page 8 you will see your ignition sense wire - a purple wire going to pin 11 on the BCM (I believe your BCM is under the steering wheel).
Unfortunately, for you, Nissan has an overengineered headlight system that uses a data bus for the actual headlight switch.  The databus information is decoded by the BCM and the info is sent through the CAN bus to the IPDM under the hood.  So, basically, there is no way to interface the lights without going under the hood.
Kevin Pierson
datboyvinh
Member - Posts: 7
Posted: June 24, 2009 at 12:27 PM / IP Logged
thanks you have been a lot of help
