2009 ford focus ses
stangbanger242
Member - Posts: 19
Posted: July 13, 2009 at 9:10 PM / IP Logged
Couple things,
Does the '09 Focus come wired already for the factory sub regardless of wether ot not it is installed, and if so what colors would they be?
Any help is appreciated, thanks
Support the TROOPS!!
Platinum - Posts: 13,726
Posted: July 13, 2009 at 9:51 PM / IP Logged
It may be wired for it, but the amplifier will not be there.  Do you know where the factory sub is installed if it had one?  There is a good chance the factory sub amp is mounted to the sub enclosure.  So if you know where it would be, you can remove that panel and look around for a plug on the end of some wires that could plug into the factory amp.
richl68
Copper - Posts: 107
Posted: July 14, 2009 at 3:49 PM / IP Logged
Radio 12VWHITE/ red+radio, gray 24 pin plug, pin 1
Radio GroundBLACK/ blue-radio, gray 24 pin plug, pin 13
Radio Ignition(CAN BUS)2009 ford focus ses -- posted image.2009 ford focus ses -- posted image.
Radio Illumination(CAN BUS)2009 ford focus ses -- posted image.2009 ford focus ses -- posted image.
Factory Amp Turn-onPURPLE / red (subwoofer amp)+radio, gray 8 pin plug, pin 4
Power Antennablack+radio, gray 24 pin plug, pin 5
Left Front Speaker (+/-)white - WHITE/ brown+,-radio, gray 24 pin plug, pins 8 and 21
Right Front Speaker (+/-)WHITE/ purple - WHITE/ orange+,-radio, gray 24 pin plug, pins 11 and 12
Left Rear Speaker (+/-)WHITE/ green - BROWN / yellow+,-radio, gray 24 pin plug, pins 9 and 22
Right Rear Speaker (+/-)BROWN / white - BROWN / blue+,-radio, gray 24 pin plug, pins 10 and 23
Center Channel (+/-)N/A2009 ford focus ses -- posted image.2009 ford focus ses -- posted image.
Subwoofer (+/-)PURPLE / green - GREEN / WHITE+,-radio, gray 8 pin plug, pins 1 and 2
Aux. Audio Input Left (+/-)blue - YELLOW /GREEN (w/o SYNC)+,-radio, gray 16 pin plug, pins 7 and 8
Aux. Audio Input Right (+/-)blue/green - WHITE/ green (w/o SYNC)+,-radio, gray 16 pin plug, pins 6 and 14
RSE Video (+/-)N/A2009 ford focus ses -- posted image.2009 ford focus ses -- posted image.
RSE Audio Left (+/-)blue - gray/orange (SYNC audio)+,-radio, gray 16 pin plug, pins 1 and 2
RSE Audio Right (+/-)PURPLE / green - BROWN / white (SYNC audio)+,-radio, gray 16 pin plug, pins 9 and 10
dcorwin822
Member - Posts: 34
Posted: September 09, 2009 at 11:59 PM / IP Logged
If its like the 08 there will be a connector in the trunk where you can tap into it. BUT it wont work because if the car didn't have a sub in it from factory the stock HU wont have a place to plug in the sub woofer harness and because of that ford cut off the harness plug.
http://www.focusfanatics.com/forum/showthread.php?t=164689
good read 'bout the 08 so it should be similar.
