1990 bmw 525i help!
tyc00
Posted: April 01, 2003 at 12:19 PM / IP Logged
I need the wiring info for my 525i. pls help ASAP
one step at a time
Platinum - Posts: 12,488
Posted: April 01, 2003 at 12:22 PM / IP Logged
|              12V|red                 |+  |steering column             |
|          STARTER|BLACK / YELLOW        |+  |steering column             |
|         IGNITION|green               |+  |steering column             |
|        ACCESSORY|purple              |+  |steering column             |
|       POWER LOCK|WHITE/ RED / yel dots  |+  |driver kick panel *1        |
|     POWER UNLOCK|blue/BROWN / yel dots |+  |driver kick panel *1        |
| PARKING LIGHTS +|gry/purple,gry/yel  |   |at light switch             |
|       HEADLIGHTS|yellow              |+  |at light switch             |
|     DOOR TRIGGER|br/gry,br/blu,br/ppl|-  |anti-theft module  *3       |
|  TRUNK/HATCH PIN|RED / white           |+  |harness to trunk            |
|       TACHOMETER|black               |   |at diagnostic conn. *2      |
|       BRAKE WIRE|blue/red            |+  |brake pedal switch          |
Notes:
*1 Do not operate locks by remote with doors open or deadbolted to prevent possible damage to servos.  *2 Round plug with screw-on cover at pass. shock tower or by fusebox on driver's side.  *3 Anti-theft plug or module located under rear seat on passenger side. Door wires also found at general module under rear seat on driver's side. Be careful handling this module, as rotating it can cause underseat grommets to suck out, allowing eventual water damage to the electrical system. Domelight supervision (combined) wire yellow/blue in large harness by general module (usually in front).
tyc00
Posted: April 01, 2003 at 12:43 PM / IP Logged
can u pls give me the stereo wiring diagram
one step at a time
Posted: April 01, 2003 at 12:55 PM / IP Logged
Sorry, the BMW has an amplifier and I do not have the color codes for the amp.
tyc00
Posted: April 02, 2003 at 2:37 PM / IP Logged
ty, if anyone passing thru has any info for me it would be greatly appreciated
one step at a time
