2002 ford explorer dome light staying on
ac_nate2424
Posted: October 09, 2009 at 12:24 PM / IP Logged
Yes i have a friend that when they close there drives side door front one that the dome light will stay on is there away to turn on the switch or to fix this so that it will turn off when he closes his door. Or if there is a switch that most cars have the turn it on when you open the door. where is that at so that i can help him disconnect it.
Platinum - Posts: 13,725
Posted: October 09, 2009 at 12:32 PM / IP Logged
In the drivers kick panel you should see a Yellow/Black wire that goes into the door boot.  That should be the wire yoiu need to cut to disable.
2002 ford explorer dome light staying on -- posted image.LF LatchYELLOW/BLACK(-)1 OF 16(SEC.MOD.) ALT.LOC. LFT KICK PAN.
2002 ford explorer dome light staying on -- posted image.RF LatchGRAY/RED(-)2 OF 16(SEC.MOD.) ALT.LOC. LFT KICK PAN.
2002 ford explorer dome light staying on -- posted image.LR LatchLIGHT GREEN/ YELLOW(-)(SEC.MOD.) ALT.LOC. LFT KICK PAN.
2002 ford explorer dome light staying on -- posted image.RR LatchPINK/LIGHT BLUE(-)7 OF 16(SEC.MOD.) ALT.LOC. LFT KICK PAN.
ckeeler
Gold - Posts: 1,461
Posted: October 09, 2009 at 1:02 PM / IP Logged
sounds like he has a bad door pin switch, which i believe is in the door latch on that make/model. sometimes you can take out the latch and clean it up and get it working again and sometimes you need to just replace the whole latch, or like the post above, just disable that door pin.
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
