1981 mercedes 300d
webxfx
Copper - Posts: 58
Posted: November 12, 2009 at 9:34 PM / IP Logged
Alarm / Starter wiring would be great if someone had it
Posted: November 13, 2009 at 3:01 AM / IP Logged
The first thing to remember is you'll need an actuator for the driver's door to control the locks.  What colours do you need?  What model?  It's pretty staight forward except for window close, switches are pos at rest.
Let me know and we'll see how good my memory is.
webxfx
Copper - Posts: 58
Posted: November 13, 2009 at 10:10 PM / IP Logged
The owner doesn't care to much about door locks, just the starter part - park lights - door pin is all I should need.
Posted: November 14, 2009 at 3:58 AM / IP Logged
Dor pins are BROWN / grey, trunk pin is positive, if I remember you can rewire the combined light/switch unit in the trunk lid to give you neg trigger. The ignition leads are all pink/colour (pink/red is ign1), starter PURPLE / ? all at ign, acc probably BLACK / YELLOW, grounds are all brown, lights all grey/? variable, headlights yellow and white with trace, idicators are BLACK/ white left and BLACK/ green right.
webxfx
Copper - Posts: 58
Posted: November 14, 2009 at 10:40 PM / IP Logged
thanks so much - so I'm guess its almost close to the 1983-84 info found here https://www.the12volt.com/installbay/alarmdetail/1415.html
Posted: November 15, 2009 at 3:51 AM / IP Logged
Yes except the 81 (W123 Model) needs an actuator as I already said and I doubt whether there's a factory alarm so my point about the trunk trigger stil applies. You wil need to relay out from your starter to connect ALL (pink primary colour) ignition leads. Tip if you can't get at them, remove the instrument panel but be careful with the rotary plug and the mechanical speedo. I've done an R/S on an 84 280CE with no grief.
Posted: November 15, 2009 at 3:54 AM / IP Logged
I just realised, your's is a deisel so that info you posted  where it mentions the coil is irrelevant!  If there's a rev counter/tacho on the instrument panel, one of it's leads, probably GREEN/ YELLOW or YELLOW /GREEN is tach, OK I can't remember!
webxfx
Copper - Posts: 58
Posted: December 06, 2009 at 8:52 PM / IP Logged
Thanks for the great tips - I'm going to be starting on it this week, I'll let you know if I have any problems
t&t tech
Platinum - Posts: 2,622
Posted: December 07, 2009 at 5:24 PM / IP Logged
Are you talking nissan 280CE howard?
Posted: December 08, 2009 at 3:00 AM / IP Logged
No dear lad and I have actually owned a Nissan or was it Datsun 280C back then as well as a Mercedes 280C. Both had hoods that could double up as an aircraft carrier.
Tuesday, April 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
