97 Supra TT 6-speed wiring diagram
michaelrc51
Member - Posts: 22
Posted: April 07, 2003 at 7:25 PM / IP Logged
I need a wiring diagram for a 97 Toyota Supra TT 6-speed for an alarm (Clifford Avantguard 4)
jayts95
Copper - Posts: 150
Posted: April 08, 2003 at 7:30 PM / IP Logged
      ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white & wht/red     |+ |ignition harness            |
|          STARTER|BLACK/ white        |+ |ignition harness            |
|        IGNITION|BLACK / YELLOW        |+ |ignition harness            |
| SECOND IGNITION|BLACK/ orange        |+ |ignition harness            |
|        ACCESSORY|pink/blue           |+ |ignition harness            |
|       POWER LOCK|GREEN/ YELLOW        |- |passenger kick panel        |
|     POWER UNLOCK|white               |- |passenger kick panel        |
| PARKING LIGHTS +|green               |   |drivers kick panel *2       |
| PARKING LIGHTS -|green               |   |steering column             |
|       HEADLIGHTS|red                 |- |steering column             |
|     DOOR TRIGGER|RED / black           |- |drivers kick panel          |
| TRUNK/HATCH PIN|tied in with door   |   |                            |
|        HOOD PIN|PURPLE / red          |- |theft ECU *3               |
|TRNK/HTCH RELEASE|                    |   |                            |
| FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|white or green      |- |drivers kick panel          |
|       TACHOMETER|black or blk/wht *1 |   |igniter *1                  |
|       BRAKE WIRE|GREEN / WHITE        |+ |plug in left kick           |
|     HORN TRIGGER|blue/red            |- |steering column             |
|           WIPERS|blue/red            |+ |steering column             |
| LF WINDOW UP/DN|RED / wht - grn/yel   |A |in drivers door             |
| RF WINDOW UP/DN|RED / blu - grn/wht   |A |in drivers door             |
Notes:
*1 On the non turbo models the tach wire is black. On the turbo models the tach wire is BLACK/ white. Both are located at the igniter located on the drivers side strut tower. *2 Bottom of fuse box in a white plug. *3 The theft ECU and door lock ECU are built together in one module. the module is located high in the passenger kick panel.
