07 acura rdx vehicle wiring
visionsss
Member - Posts: 19
Posted: December 20, 2009 at 3:57 PM / IP Logged
Need vehicle wiring for 07 Acura RDX. Doing a Remote Start Alarm and possibley window roll up if I can get the wire info.
Thanks,
Fred Kincaid
Visions Sound & Security
GPS Northwest
Platinum - Posts: 13,725
Posted: December 20, 2009 at 4:47 PM / IP Logged
07 acura rdx vehicle wiring -- posted image.BatteryWHITE (50A)(+)IGNITION SWITCH HARNESS
07 acura rdx vehicle wiring -- posted image.Ignition 1BLUE(+)IGNITION SWITCH HARNESS
07 acura rdx vehicle wiring -- posted image.Starter 1YELLOW(+)IGNITION SWITCH HARNESS
07 acura rdx vehicle wiring -- posted image.All Door TriggerSEE NOTE07 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.Domelight SuperPINK(-)DRIVER KICK REAR OF FUSE BOX 8 PIN PLUG07 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.LF LatchGREEN(-)DRIVER KICK OR 42 PIN PLUG TOP OF FUSE BOX PIN 3707 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.RF LatchGREEN(-)DRIVER KICK OR 42 PIN PLUG TOP OF FUSE BOX PIN 307 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.LR LatchBROWN(-)DRIVER KICK OR 42 PIN PLUG TOP OF FUSE BOX PIN 1707 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.RR LatchBLUE(-)DRIVER KICK OR 42 PIN PLUG TOP OF FUSE BOX PIN 207 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.Trunk TriggerBLUE(-)DRIVER KICK OR 42 PIN PLUG TOP OF FUSE BOX07 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.Hood TriggerYELLOW/RED OR GRAY(-)PIN SWITCH OR FUSE BOX MID 21 PIN PLUG.07 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.Alarm DisarmBROWN(-)DRIVER'S KICK OR MICU PIN 31 OF 34 PIN PLUG07 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.Alarm ArmPINK(-)DRIVER'S KICK OR MICU PIN 32 OF 34 PIN PLUG07 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.Parking LightsRED(+)DRIVER'S KICK OR FUSE BOX TOP PLUG07 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.Low Crr Pk LightsGRAY(-)AT SWITCH OR MICU,20 PIN PLUG PIN 13
07 acura rdx vehicle wiring -- posted image.Accessory 1ORANGE(+)IGNITION SWITCH HARNESS
07 acura rdx vehicle wiring -- posted image.Accessory 2RED(+)IGNITION SWITCH HARNESS
07 acura rdx vehicle wiring -- posted image.Anti-Theft TypeUNIVERSAL IMMOBILIZER
07 acura rdx vehicle wiring -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
07 acura rdx vehicle wiring -- posted image.Key SensePINK(-)IGNITION SWITCH HARNESS
07 acura rdx vehicle wiring -- posted image.TachometerUSE FUEL INJECTOR(AC)BROWN / W. STRIPE ANY INJECTOR
07 acura rdx vehicle wiring -- posted image.Speed SenseBLUE(AC)RADIO HARNESS07 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.Low Crr. Pk LightsGRAY(-)AT SWITCH OR MICU,20 PIN PLUG PIN 1307 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.Brake LightsLT.GREEN(+)DRIVER'S KICK OR FUSE BOX07 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.Reverse LightsLT. BLUE(+)DRIVER'S KICK OR FUSE BOX07 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.HornORANGE(-)SWITCH OR REAR OF FUSE BOX 16 PIN PLUG
Posted: December 20, 2009 at 4:48 PM / IP Logged
07 acura rdx vehicle wiring -- posted image.Power UnlockGRAY(-)DRIVER'S KICK OR MICU PIN 27 OF 34 PIN PLUG07 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.PowerLockBLUE(-)DRIVER'S KICK OR MICU PIN 28 OF 34 PIN PLUG07 acura rdx vehicle wiring -- posted image.
07 acura rdx vehicle wiring -- posted image.Driver Mtr UnlockLT. BLUE(REV)DRIVER KICK OR REAR OF FUSE BOX
07 acura rdx vehicle wiring -- posted image.Driver Mtr LockGRAY(REV)DRIVER KICK OR REAR OF FUSE BOX
07 acura rdx vehicle wiring -- posted image.Pas Mtr UnlockYELLOW(REV)PASS KICK OR 10 PIN PLUG REAR OF FUSE BOX
07 acura rdx vehicle wiring -- posted image.LF Window UpLT.BLUE
07 acura rdx vehicle wiring -- posted image.LF Window DnRED
07 acura rdx vehicle wiring -- posted image.RF Window UpYELLOW
07 acura rdx vehicle wiring -- posted image.RF Window DnRED
07 acura rdx vehicle wiring -- posted image.LR Window UpBLUE
07 acura rdx vehicle wiring -- posted image.LR Window DnRED
07 acura rdx vehicle wiring -- posted image.RR Window UpBLUE
07 acura rdx vehicle wiring -- posted image.RR Window DnRED
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
