mercury cougar diagram
grandpaswagon
Posted: December 22, 2009 at 12:24 PM / IP Logged
Hello, just found this place and it looks like a ton of good info. I am trying to install a remote power mirror switch for a 99-02 Mercury Cougar into my Jeep Grand Wagoneer.
I have the wiring information for the Jeep, but need to know what each wire on the Mercury switch is for.
Can anyone provide the Remote Power Mirror Switch wiring information for a 1999-2002 Mercury Cougar?
Thank you.
Ween
Platinum - Posts: 1,368
Posted: December 22, 2009 at 10:22 PM / IP Logged
hi,
notch at top, starting from upper left as pin 1, from left to right
pin1...pass left/right motor, pin 2... not used, pin 3...driv left/right motor, pin 4...ground, pin 5...motor common, both driv & pass, pin 6...+ 12 volts, pin 7...pass up/down motor, pin 8...driv up/down motor.
m
grandpaswagon
Posted: December 23, 2009 at 8:45 AM / IP Logged
Thankyou. I'll look at it tonight when I get home and see if the pinouts work.
