2003 Kia Rio Stereo Wiring
zacisblack
Posted: January 26, 2010 at 9:50 PM / IP Logged
I want to install my stereo myself but cannot figure out the wiring. Can someone supply me with a diagram of chart of the wires and what they are for in my car.
j.reed
Copper - Posts: 716
Posted: January 26, 2010 at 11:16 PM / IP Logged
FUNCTION     PIN     WIRE COLOR
Accessory 12 Volt     1     BN/RD
Constant 12 Volt     9     YW/BU
Chassis Ground     16     BK
Power Antenna
Remote
Illumination     9     BU/BK
Dimmer     2     BU/WT
FUSE VALUE     FUSE LABEL     FUSEBOX LOCATION
10 AMP     "AUDIO"     DRIVER'S SIDE DASH PANEL
15 AMP     "ROOM"     DRIVER'S SIDE UNDER HOOD
Left Front Spkr +     5     WT/GN
Left Front Spkr -     14     WT/RD
Right Front Spkr +     4     YW/BU
Right Front Spkr -     11     YW/RD
Left Rear Spkr +     6     RD/BK
Left Rear Spkr -     15     RD/GN
Right Rear Spkr +     3     L.GN/YW
Right Rear Spkr -     10     L.GN/RD
I would use a Metra 70-1003 Radio Wiring Harness. It shows to be the correct one for your vehicle. No need to cut the factory harness and i highly advise not cutting. Use the above to ensure correct pin placement. Looks like the Metra 99-1007 Is the kit including wire harness and mounting bracket.
2003 Kia Rio Stereo Wiring -- posted image.
zacisblack
Posted: January 27, 2010 at 11:18 PM / IP Logged
Hey I busted a fuse for illumination in my car and I fixed it but my clock and inside lights don't work. I tried connecting just the power to the receiver but it doesn't come on. Do you think I busted a fuse in the "room" location of my car? If i connect just the yellow cable to the constant and the red cable to ACC should the stereo come on? and also where do I connect the illumination and dimmer wires?
poonamt93
Posted: January 28, 2010 at 3:03 AM / IP Logged
2003 Kia Sedona Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green
Car Radio Accessory Switched 12v+ Wire: BLACK / YELLOW
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Blue / YELLOW
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): Light GREEN/ YELLOW
Right Front Speaker Negative Wire (-): BLACK/ Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): GREEN/ YELLOW
Left Rear Speaker Negative Wire (-): Blue/Orange
Right Rear Speaker Positive Wire (+): GREEN / WHITE
Right Rear Speaker Negative Wire (-): GREEN/ Blue
Hope this will help you.....
zerepdivad
Silver - Posts: 605
Posted: January 30, 2010 at 12:53 AM / IP Logged
You should have spent the 5-20 bucks on the proper harness. C'mon it's a 2003 not an 80's caprice.
A DMM is a beautiful thing.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
