remote starter
Augi
Posted: April 09, 2003 at 8:34 AM / IP Logged
2003 Dodge Durango wiring request
afesi
jayts95
Copper - Posts: 150
Posted: April 09, 2003 at 5:37 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|pnk/blk & RED / lt blu|+ |ignition harness            |
|          STARTER|yellow              |+ |ignition harness            |
|        IGNITION|blue               |+ |ignition harness            |
| SECOND IGNITION|GREEN/ red    (18 ga)|+ |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+ |ignition harness            |
| SECOND ACCESSORY|green               |+ |ignition harness            |
|       POWER LOCK|WHITE/ green        |*1 |conn. 2, pin 10 @ CTM *2    |
|     POWER UNLOCK|same wire           |   |                            |
|       LOCK MOTOR|ORANGE / black        |   |conn. 2, pin 4 @ CTM *2     |
|     UNLOCK MOTOR|blue               |   |conn. 2, pin 6 @ CTM *2     |
|    DISARM DEFEAT|pink/black          |   |conn. 2, pin 5 @ CTM *2     |
| PARKING LIGHTS +|BLACK / YELLOW        |   |headlight switch            |
| PARKING LIGHTS -|RED / yellow          |   |conn. 1, pin 4 @ CTM *2     |
|       HEADLIGHTS|lt. GREEN/ orange    |- |headlight switch            |
|     DOOR TRIGGER|*3                  |- |CTM *2                      |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|tan/black           |- |conn. 2, pin 7 @ CTM *2     |
| FCTRY ALARM ARM|lt. GREEN/ orange    |*4 |conn. 2, pin 14 @ CTM *2    |
|FCTRY ALRM DISARM|same wire           |   |                            |
|       TACHOMETER|*5                  |   |ignition coil               |
|      SPEED SENSE|WHITE/ orange or blue|   |conn. 2, pin 27 @ PCM *6    |
|       BRAKE WIRE|WHITE/ tan           |+ |brake pedal switch          |
|     HORN TRIGGER|BLACK/ red           |- |steering column or CTM *2   |
|           WIPERS|purple(L), RED / gry(H|+ |steering column             |
| LF WINDOW UP/DN|lt. blue - white    |A |driver window switch        |
| RF WINDOW UP/DN|brn/wht - pur/wht   |A |driver kick panel           |
| LR WINDOW UP/DN|blu/wht - RED / blk   |A |driver kick panel           |
| RR WINDOW UP/DN|gry/blk - grn/wht   |A |driver kick panel           |
|        RADIO 12V|pink               |+ |radio                      |
|     RADIO GROUND|black               |- |radio                      |
|     RADIO SWITCH|RED / white           |+ |radio                      |
| RADIO ILLUMINATE|white               |+ |radio                      |
|       LF SPEAKER|lt grn/pu-lt grn/grn|   |radio                      |
|       RF SPEAKER|lt blu/pu-lt blu/blk|   |radio                      |
|       LR SPEAKER|wht/red - wht/blk   |   |radio                      |
|       RR SPEAKER|tan/pur - tan/blk   |   |radio                      |
Notes:
NOTE: Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U. *1 Lock is negative trigger thru a 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays. *2 The Central Timer Module is in the driver kick panel. *3 The driver door trigger is tan in connector 2, pin 15. The passenger door trigger (and rears) is tan/red in connector 2, pin 13. Use both and diode isolate each. See directfax document #1076 for wiring information. *4 Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger thru a 1565 ohm resistor. MUST use relays. This wire will also lock the doors, and it will unlock with a double pulse. *5 On the 5.9L models use BLACK/ gray at the ignition coil. The 4.7L models have an ignition coil for each cylinder, use the wires that is NOT GREEN/ orange at one of the coils. *6 The Powertrain Control Module is on the passenger fender.
