95 jeep grand cherokee factory alarm?
1funkycat
Member - Posts: 6
Posted: April 09, 2003 at 9:26 PM / IP Logged
Hi evrybody,
I am having a hard time trying to locate the stock alarm on my jeep. I need to disable (not just disarm it) it so i can install a new remote start alarm. Is there an easy way to disable it? Does anyone know where it is?
Thanks,
matt
Moderator - Posts: 12,488
Posted: April 09, 2003 at 9:33 PM / IP Logged
There is a PURPLE / YELLOW wire found in the lower driver's kick panel area and all you need to do is run a jumper wire to ground and attach the other end of the wire to the PURPLE / YELLOW  wire and this will permanently DISARM the OEM security system as long as there is a GROUND on this wire.
1funkycat
Member - Posts: 6
Posted: April 10, 2003 at 7:20 AM / IP Logged
Thanks alot Jeff, you have been a huge help!
Posted: April 10, 2003 at 7:59 PM / IP Logged
No problemo..... if you have any further problems or questions, just post them here.
Thursday, December 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
