2002 caravan
bignookie
Member - Posts: 11
Posted: March 04, 2010 at 10:00 AM / IP Logged
Does anyone know how to disarm the factory alarm ? what's the easiest way ?
Platinum - Posts: 7,827
Posted: March 04, 2010 at 10:24 AM / IP Logged
Using a R/S system DisArm (-) output as follows:
2002 Dodge Caravan                  info from Bulldog Security
FACTORY ALARM DISARM      PURPLE / LT.BLUE (-) See NOTE *9       @BCM, CONNECTOR 3, PIN 14
NOTE * 9 This vehicle will DISARM with (-)Negative thru a 9000 Ohm resistor,
MUST use SINGLE pulse to DISARM and a DOUBLE pluse on this wire will also UNLOCK.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
