04 mustang mach 460 diagram
mark18519
Posted: March 15, 2010 at 10:35 PM / IP Logged
I am installing an '04 mach460 6 disc into a '96 cobra. I am using metra's harness 71-5520-1 to wire it into the existing wiring. I have the 24-pin connector working and the unit works and I get tweeter sound, but I need a pinout diagram for the 8-pin connector on the back of the headunit. I have no sound from the rear "subwoofer" amps.
Metra's diagram is so vague I can't get anything from it.
Any help is appreciated, thanks
mark18519
Posted: March 16, 2010 at 11:55 AM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp?tid=51199&KW=ween
that is exactly what I need, but the attached images no longer work :(
Ween
Platinum - Posts: 1,368
Posted: March 16, 2010 at 3:38 PM / IP Logged
looking at the rear of the radio, make the upper left pin 1. going across 2, 3, 4 will be the upper right.  pin 5 lower left, pin 8 lower right.
pin 1 ... sub signal +, pin 2 ... sub signal -, pin 3 ... sub signal shield, pin 4 ... sub enable
m
mark18519
Posted: March 16, 2010 at 7:33 PM / IP Logged
Thanks Ween I got it working and it sounds great !
