need 2004 impala amp wiring diagram
guy48065
Posted: March 22, 2010 at 8:47 PM / IP Logged
My 02 Aurora was just totalled so I pulled out the remote start & a small powered Bazooka tube to install in a 2004 Impala. (I think I'll leave the remote atart to a shop)
Looks like the factory amp is in the trunk which should make it real easy to tap into the wires for the Bazooka if I knew the pinout :)
Also is there a more stout 12V source in the trunk area I can use for this fairly low-powered amp?
Platinum - Posts: 13,726
Posted: March 22, 2010 at 9:48 PM / IP Logged
Look at the wire colors on the amp and see if these wires are all located in the same area of the plug.
need 2004 impala amp wiring diagram -- posted image. LF Speaker (+) TAN
need 2004 impala amp wiring diagram -- posted image. LF Speaker (-) GRAY
need 2004 impala amp wiring diagram -- posted image. RF Speaker (+) LIGHT GREEN
need 2004 impala amp wiring diagram -- posted image. RF Speaker (-) DARK GREEN
need 2004 impala amp wiring diagram -- posted image. LR Speaker (+) BROWN
need 2004 impala amp wiring diagram -- posted image. LR Speaker (-) YELLOW
need 2004 impala amp wiring diagram -- posted image. RR Speaker (+) DARK BLUE
need 2004 impala amp wiring diagram -- posted image. RR Speaker (-) LIGHT BLUE
