cobalt bypass module
katmst2
Member - Posts: 6
Posted: April 11, 2010 at 7:21 PM / IP Logged
What is the correct bypass module to add remote start to a 07 chevrolet cobalt   I have found so many not sure what to use and have it last
Platinum - Posts: 7,828
Posted: April 11, 2010 at 10:04 PM / IP Logged
Your car has the PassKey 3+ immobilizer system.
 Depending on the cars options ( power locks, alarm, etc )  you could get a bypass that does only the bypass function or get one that does a lot more.
 The basic bypass uses a transponder and ring antenna.  They are less expensive but  antenna positioning and extreme cold can make them less reliable.
The better modules use a data connection to bypass the cars immobilizer.  They cost more and usually require loading them application specific firmware with a special cable.
There is one brand that does everything and comes preloaded with the correct firmware.  Check out the Fortin CAN SL2 at :  https://ifar.ca/en/products/flash/can-sl2/files.html
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
