2010 nissan pathifnder
slammedniss
Member - Posts: 40
Posted: April 15, 2010 at 2:48 PM / IP Logged
Wiring diagram request
mpe235
Copper - Posts: 90
Posted: November 08, 2010 at 8:26 PM / IP Logged
 MODEL  YEAR(S)
 PATHFINDER  2007 -2010
 KEY  T-HARNESS  IMMOBILIZER
  N/A   N/A   NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1
 PART   COLOR  LOCATION
 12 VOLT CONSTANT   GREEN (+) 40 AMP   @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 3
 STARTER  GRAY (+)  @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 2
 STARTER 2  LT. GREEN (+)  @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 6
 IGNITION 1  WHITE/ GREEN (+)  @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 1
 IGNITION 2  N/A
 IGNITION 3  N/A
 ACCESSORY /HEATER BLOWER 1  RED (+)  @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 4
 ACCESSORY /HEATER BLOWER 2  GREEN/ YELLOW (+)  @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 5
 KEYSENSE  N/A
 PARKING LIGHTS ( - )  N/A
 PARKING LIGHTS ( + )  GRAY (+)
 POWER LOCK  LT. BLUE (-), TYPE B, NOTE #3  @ POWER WINDOW Main Switch, ( WHITE, 16-PIN PLUG), PIN 4
 POWER UNLOCK  RED / WHITE (-), TYPE B, Requires Double Pulse, NOTE #4  @ POWER WINDOW Main Switch, ( WHITE, 16-PIN PLUG), PIN 6
 DOOR TRIGGER  GRAY (-)  in DRIVERS KICK PANEL or BCM, (WHITE, 15-PIN PLUG), PIN 7, NOTE #2
 DOMELIGHT SUPERVISION  BROWN (-)  in DRIVERS A Pillar or BCM, (BLACK, 15-PIN PLUG), PIN 8, NOTE #2
 TRUNK RELEASE  GREEN or LT. BLUE (-) NOTE #5  in DRIVERS KICK PANEL or BCM, (WHITE, 40-PIN PLUG), PIN 30, NOTE #2
 SLIDING POWER DOOR  N/A
 HORN  BROWN (-)  @ HORN Switch, (GRAY-8-PIN PLUG), PIN 2 or in DRIVERS KICK PANEL
 TACH  Any wire NOT WHITE/ GREEN (AC)  @ Any FUEL-INJECTOR
 WAIT TO START LIGHT  N/A
 BRAKE  YELLOW (+)  @ BRAKE SWITCH or in DRIVERS KICK PANEL, Harness to REAR of Vehicle
 FACTORY ALARM DISARM   Use UNLOCK wire
 ANTI-THEFT  NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, See NOTE #1
 EXTRA INFORMATION
 NOTE #1: NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 (For REMOTE START ONLY) Part # DLPK-CANBUS MULTI (for REMOTE START and DOOR LOCKS) NOTE #2: the BCM (Body Control Module) is located under the Drivers Dash and to the RIGHT of the Steering Column. NOTE #3: TEST this wire while Turning the KEY in the Drivers Door. This wire will also ARM the FACTORY ALARM. NOTE #4: TEST this wire while Turning the KEY in the Drivers Door. This wire will also DISARM the FACTORY ALARM. NOTE #5: TEST this wire while opening the LIFTGATE with the Handle on the REAR of the Vehicle.
Nissan Master Tech.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
